Creaky Clutch Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kwik, Feb 12, 2014.
  1. Feb 12, 2014 at 6:02 PM
    Kwik
    Kwik [OP] Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    Lately I have been having problems with my clutch pedal creaking after a while of driving. I have tried greasing all the moving parts in the clutch assembly but the creaking won't go away.
    Has anyone else had this problem?
    Any suggestions?
    Thanks
  2. Feb 12, 2014 at 6:18 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There is a TSB for creaky clutch pedal. My experience is the TSB doesn't work for long.
  3. Feb 12, 2014 at 7:04 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    I've had the throw out bearing replaced & 2 clutch pedals break. So, no it doesn't go away.
  4. Feb 12, 2014 at 7:09 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Rotate the connecting rod a quarter turn. Worked for me hasn't creaked in years.
  5. Feb 12, 2014 at 7:17 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    If the creaking you speak of is coming from up under the pedal, grab a flashlight and some white lithium grease and spray a little up under where the clutch pedal arm makes contact. That is where the creak comes from. I have to spray a little grease up there once every couple months. Don't bother with taking to the dealer. I know its annoying, but thats what you have to do if the creak starts to annoy you bad enough.
  6. Feb 12, 2014 at 7:18 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    This! I've done this on 3 different tacoma's and they've all stopped creaking
  7. Feb 12, 2014 at 7:22 PM
    reece13
    North Carolina
    Good to know.
  8. Feb 12, 2014 at 10:58 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I've sprayed mine with white lithium grease & it's been quiet. I'll try rotating the connecting rod if the creak returns. Thanks!
  9. Feb 17, 2014 at 10:19 PM
    Kwik
    Kyle
    Seattle
    The noise is definitely coming from the inside. I will try rotating the connecting rod. Thanks!
    -Kyle
  10. Feb 18, 2014 at 1:53 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    That noise is chronic. My 2000 first gen. creaked. Anything I did to it would work for a few weeks only. My 2009 has just started to do it. Thanks for the tip.
  11. Mar 25, 2014 at 6:59 AM
    MidMO TACO
    MidMO TACO Active Member
    Daniel
    Columbia,MO
    '12 a.c., SR5 ,4x4 ,v6, 6spd mt
    Nothing but a softtopper yet
    Just did this ,after the dealer couldn't find it the last two times it was in for service.
    Glad I finally searched for some help on this problem...
  12. Mar 25, 2014 at 7:01 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    :cheers:
  13. Mar 25, 2014 at 7:14 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Mine was creaking for a bit but then it went away. I'll remember this fix/hack though if it comes back!
  14. Feb 26, 2015 at 7:33 AM
    TacoBully
    TacoBully Well-Known Member
    CJ
    RI
    2014 4X4 Access Cab
    After a while the connecting rod trick no longer works. Just so you know. I have a 2014.
