Creaky Coilover, need help
Discussion in 'Suspension' started by jvand678, Jan 20, 2009.
  1. Jan 20, 2009 at 8:05 PM
    jvand678
    jvand678 [OP] Well-Known Member
    Lubbock, TX
    '12 Dbl CabTRD Sport 4x4 Black
    Westin Nerf bars, full window tint, redline hood struts, Icon Coilovers, Wheeler Add a Leaf 3 pack (on its way)
    Hey guys,
    I installed my swayaways 2 weeks ago and we got a little bit of weather. After all the road crud dried up I now have some noise coming from the left coilover. I wiggled around on the pickup spraying spots with my silicone can until I found it. Problem is, the silicone dries up in about a day or two. Is there anything I can use that will either clean the thing up, lube it up really well or should I just learn that when you modify things, creaks happen?
    thanks,
    Joe
  2. Jan 20, 2009 at 8:09 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    bychance is it coming from the lower bushing?
  3. Jan 20, 2009 at 8:37 PM
    jvand678
    Lubbock, TX
    If you're talking about the bushing that bolts onto the lower control arm, no, it's actually coming from what I think is the seal. Can't really find a diagram that gives the exact name. It's where external part of the piston goes inside. I have to actually spray inside the spring and at this seal to make it stop.
  4. Jan 20, 2009 at 8:39 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    ah...i have no fix :( sorry
    mine were squeeking at the lower bushing (where it mounts to the LCA)
    i just sent them off to get rebuilt though
  5. Jan 20, 2009 at 8:49 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Allot of times its coming from the spring itself rubbing against the body of the shock, especially SAW's-
