Cream puff truck crap frame
Discussion in 'New Members' started by Toyo hater, Oct 15, 2020.
  1. Oct 18, 2020 at 8:18 AM
    #141
    TrdSurgie
    TrdSurgie revised
    Oahu
    That definitely qualifies.
    CygnusX191 likes this.
  2. Oct 18, 2020 at 8:20 AM
    #142
    Toyo hater
    Toyo hater [OP] New Member
    Cream puff with crap frame
    I would like to hope.
  3. Oct 18, 2020 at 8:28 AM
    #143
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    High strength steel is typically prone to rust. In a strange reversal of what you might assume, the stronger the steel the more rust prone, due to high levels of carbon in the steel. This is why they don’t make stainless steel frames etc......even it it wasn’t cost prohibitive.
    Toyota failed OP by not putting even the most basic of durable coatings on the frame. That’s all on Toyota, not Dana. They just didn’t care, and maybe it’s come back to bight them.
    There are cast-iron bridges in England that are still standing because they painted them properly.
    My work truck is a Ford F-150 that has Fords ‘e-coated’ frame. I’m running an experiment as my work truck will be traded in before frame rust is ever a problem. After two years with no cleaning......none at all.......many gravel miles.....and two salty winters.....the Ford frame has minimal, if any rust. Toyota frames leave the lot rusty.
    It’s one category that Toyota chooses to deliberately cheap out on, and only on their truck frames. The cars are fine.
  4. Oct 18, 2020 at 8:33 AM
    #144
    Toyo hater
    Ok black dog, no I never coated with fluid film. Never heard of it until this forum. I'm not computer savvy and I have only had a smartphone for less than a year. Dinosaur that I am I was relying on the dealership to inform me during maintenance and inspection visits. They just kept telling me it was ok. Now don't I feel foolish for believing them.
  5. Oct 18, 2020 at 8:41 AM
    #145
    Toyo hater
    I have a new friend who is an expert at rustproofing, painting, and vehicle maintenance. He is the one who discovered the severity of the problem. He thinks some of the problem is due to the amount of welding on the frame because the heat weakens the steel.
  6. Oct 18, 2020 at 8:57 AM
    #146
    Stocklocker
    17TRDORDCSBAT
    The welding doesn’t help, but is common to many frames. Most are welded together. Weakness is not what causes a frame to rust. It’s exposure to the elements. If you properly coat your welds, all is good.
  7. Oct 18, 2020 at 9:01 AM
    #147
    Toyo hater
    My frame was coated at some point before I owned it. Had no idea it had to be done over and over and over again.
  8. Oct 18, 2020 at 9:19 AM
    #148
    Stocklocker
    17TRDORDCSBAT
    Hopefully it wasn’t coated with rubberized undercoating (Ziebart etc). If so, that’s why your rust is so bad. The oil and wool-wax based coating like Fluid Film don’t trap moisture against the frame like the rubber stuff does. Ziebart etc, guarantees the death of your frame.
    If you get a new frame, don’t let them put any rubberized coating on it. Fluid Film is not that.
    When I was discussing coatings I was referring to the factory paint, or coating, not undercoating.
    CygnusX191 and Plain Jane Taco like this.
  9. Oct 18, 2020 at 9:26 AM
    #149
    Toyo hater
    Not rubberized. Not sure what it is. Thanks for the advice
    Stocklocker likes this.
  10. Oct 18, 2020 at 9:56 AM
    #150
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Oddly enough, I have the opposite experience at work with our Fords. They rust out bad.... And we wash the jebeebus out of them after every snow shift. Lol
  11. Oct 18, 2020 at 9:59 AM
    #151
    Toyo hater
    Maybe you're washing them too much.
  12. Oct 18, 2020 at 10:03 AM
    #152
    Toyo hater
    I have two friends with similar trucks. (Chevys) One washes his a lot the other rarely washes his. Guess which one has the most rust.
  13. Oct 18, 2020 at 10:41 AM
    #153
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The one without corrosion prevention.
    DUH !
  14. Oct 18, 2020 at 10:44 AM
    #154
    Toyo hater
    What makes you think one has it and one doesn't?
  15. Oct 18, 2020 at 11:34 AM
    #155
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Lol after spending 12+ hour shifts plowing snow, salting roads, and throwing down chemicals, there is no such thing as "washing them too much"
    We actually fluid filmed everything this year, including the 10 and 20 ton dump trucks. Should be interesting to see how that affects things
  16. Oct 18, 2020 at 11:54 AM
    #156
    Toyo hater
    Didn't know you are a snow removal company. That's really hard on equipment for sure.
  17. Oct 18, 2020 at 12:37 PM
    #157
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    DoT. Even harder on equipment lol
    whiteknight4x4 likes this.
  18. Oct 18, 2020 at 12:40 PM
    #158
    Toyo hater
    Ok you didn't say that, now I get it. What is the average lifespan of a DOT truck?
  19. Oct 18, 2020 at 12:56 PM
    #159
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Pickups (F-350s) 5 or so years.
    Dump trucks (10 tons and up) 8-12 years, depending on useage and configuration. Although the last 2 or so years for most of them they're basically glorified likes of rust shaped like a truck.
    F-450 w/ dump beds - current on at my shop is entering it's 12th year of service. It really should have been replaced 3 years ago.
    This is all in St. Louis, MO, where any given week of the year we see 3 seasons.
  20. Oct 18, 2020 at 1:16 PM
    #160
    Toyo hater
    WOW. I'm sure it takes a tremendous amount of maintenance to keep them going.
