Creeking sound from the front while starting off
Discussion in 'Suspension' started by hookedontronics, Nov 17, 2011.
  1. Nov 17, 2011 at 6:36 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    This past week i added DSM upper control arms and 285/65-18" tires to my truck. I also cranked down my Icon extended coilovers from 1.75" and 1.5" thread to 2.25" and 2" thread showing. Now the icon literature said 2" of thread max but i spoke with them and they said that is old literature and that as long as you have 2" of downtravel that is what they recommend, and i have just a hair over that. Now another thing i did was grease up my UCAs after i installed them, and not beofre i assembled them.
    So anyways...now when i start off from a stop i hear a little creeking in the front, checked over everything and it's all tight. I'm not sure if this is because of the weight/size of the new tires (i had stock size on before with this lift, and this is the first time i've ever added bigger tires to a truck), or if it's because my UCAs possible need more lube since i lubed them up after i installed them. Could also be that my coilovers are just wearing in to the new position as well, or maybe it's just the bushings on them.
    Think it's anything to worry about? Any possible suggestions. I first thing i'm going to do it hit the UCAs with more greese since maybe they will take a little more now that they've had some travel to them
  2. Nov 17, 2011 at 7:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does it do the same thing in reverse?
    How loud is it?
    Are you sure the noise is coming from the front end?
    If everything you've done is new - suspension work and all the changes you've done will take time to 'settle in'. Give it a few days .....
  3. Nov 17, 2011 at 7:12 AM
    hookedontronics
    Jake
    Glenville, NY
    yeah does the same in reverse, it's not too loud but i can hear it. It's been a week today, about 400 miles on the truck so far
  4. Nov 17, 2011 at 9:40 AM
    Janster
    Jandy
    Lancaster, PA
    The only thing I can think of at this point - When was the last time you greased your driveshafts? (ujoints)
    Perhaps the extra height and the different operating 'angle' (per say) - and if you haven't greased them in a while. Worth doing it anyway if it hasn't been done in a while. I've had stranger things happen....that were totally unrelated.
    Does it 'creek' while in drive? And what I mean is.... if you stop the truck on a down hill, put it in neutral and let it coast forward (no gas, no drive) - does it still make the creeking sound?
  5. Nov 17, 2011 at 11:17 AM
    hookedontronics
    Jake
    Glenville, NY
    I will give that a try and write back, but I am pretty sure the answer is yes
  6. Nov 17, 2011 at 11:28 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    you know cold weather and snow kindv'e does that for me, a creaking sound when starting to drive ( like something is locked up until i start driving). you have any snow/cold weather where your at? if you have a garage (heated) test out that theory and see if it still does that when at summer time temps.
    Just a thought.
  7. Nov 17, 2011 at 11:30 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i have a weird noise when i just start moving forward or back, turns out it was my break pads moving
  8. Nov 17, 2011 at 1:09 PM
    hookedontronics
    Jake
    Glenville, NY
    Could very well be my brakes, i have about 40kmi on the stock ones
  9. Nov 18, 2011 at 8:16 AM
    hookedontronics
    Jake
    Glenville, NY
    Does anyone think removing my sway bar would help?
  10. Nov 18, 2011 at 11:58 AM
    Janster
    Jandy
    Lancaster, PA
    No.... You need to find the source of the problem. Removing the sway bar will only hide it.
    Besides - removing the sway bar will change the driving characteristics making it tilt/lean in the corners. And if you ever have to make a quick abrupt turn to avoid an accident - having that sway bar could make the difference between keeping all 4 wheels on the ground or not.
  11. Dec 7, 2011 at 6:05 AM
    hookedontronics
    Jake
    Glenville, NY
    I wanted to update this and let everyone know what the deal was. I greesed my ucas again once they had some time to articulate and the sound is gone, pretty sure that's all it was since i never lubed them before install and only greesed them after they were on. Anyways, creeking sound is no more
