Cricket chirping sound that goes away with slight clutch pressure...???
Discussion in '4 Cylinder' started by cms81586, Aug 22, 2012.
  1. Aug 22, 2012 at 8:56 AM
    cms81586
    cms81586 [OP] New Member
    AZ
    06 Reg Cab 4x4 four banger
    I have an 06 2.7L 4cyl Tacoma Base 6 Lug 4x4 that has a slight chirping sound both at idle and while running (frequency of chirping matches engine speed). I don't have an automotive stethescope so I can't isolate where it's coming from, but when I apply pressure to the clutch (just enough travel to start feeling pressure) it goes away. I'm thinking either a bearing somewhere in the clutch...but also considering that it may be a pulley bearing. I replaced the serpentine belt about 5k miles ago and I'm considering getting a new belt tensioner, but I don't know applying slight pressure to the clutch would cause the noise to cease. Any ideas on where to start looking?
    CMS
  2. Aug 22, 2012 at 8:57 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Throw out bearing on the clutch. Just a guess
  3. Aug 22, 2012 at 9:17 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    THROWOUT BEARING. It is a sealed bearing and sounds like it is getting dry, once that happens the friction increases and failure is certain.
  4. Aug 22, 2012 at 9:19 AM
    rsj78
    rsj78 Well-Known Member
    Scott
    Virginia
    2012 Tacoma TRD Sport 4WD
    Bilstein 6112's, Icon progressive AAL, Specialty Products Upper Control Arms, TRD Catback, Alpine head unit, Husky Liners mats, AVS in-channel visors, Husky Liner Mud Guards, Bullaculla Trailer harness Relocate Bracket, TRD shift knob
  5. Aug 22, 2012 at 11:52 AM
    cms81586
    AZ
    Appreciate the help guys. Any suggestions for clutch mods while I'm in there?
