Cricket noise? possibly clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TahDah, Mar 19, 2012.
  1. Mar 19, 2012 at 11:28 PM
    TahDah
    TahDah [OP] New Member
    Irvine
    Just Getting Started
    K&N Aircharger, Billet Grill
    Im having an issue with my 06 tacoma. Its a Xtracab, 4x4, 4.0L v6, with trd offroad package and tow package with about 80,000 miles on it. There is a churping noise that started off only when the clutch was not engaged and in neutral. now i can hear it in first and second gear at slow speed. the churping goes away if i press the clutch pedel half way but if it is fully pressed down or not being pressed at all then it churps loud and proud. Do i need a new clutch? any recommondation on brands or type?:confused:
  2. Mar 19, 2012 at 11:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Search "throw out bearing". It's a common problem and the parts involved have been updated. Make sure you get the updated parts or you run the risk of it reoccuring.
