"Crickets" sound from tranny
Discussion in 'Technical Chat' started by haolerot, Mar 27, 2012.
  1. Mar 27, 2012 at 11:28 PM
    haolerot
    haolerot [OP] Well-Known Member
    03 Tacoma TRD
    My truck makes a cricketish noise whenever my truck is on, below 2.5k rpms. It does not matter which gear it's in or if it's in neutral. Pressing on the clutch a tiny bit will make the sound go away.
    I've taken it to the dealer, and just by "hearing the sound" he stated it was my release bearing. I bought my 03 four years ago and it came with a 3rd party 5 year warranty, but the warranty states it doesn't cover clutch components as its a wear and tear item.
    Taking off that boot on my tranny that covers the fork area, if I spray white lithium grease will make the sound go away for 2 days.
    Any clue what else this could be? Or any other remedies that will help fix this?
  2. Mar 27, 2012 at 11:36 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    Yep throw out bearing or release bearing, same thing, thats what they sound like when they are getting bad
  3. Mar 28, 2012 at 12:37 PM
    haolerot
    03 Tacoma TRD
    Even in Neutral?
  4. Mar 28, 2012 at 6:57 PM
    haolerot
    03 Tacoma TRD
    When I apply figure pressure to the clutch fork or even to the boot, the sound also goes away? Could it be the clutch fork is misaligned?
    Also, I've read that adjusting the clutch rod to reduce the amount of play in the pedal could help. But wouldn't i be grinding the clutch?
  5. Mar 28, 2012 at 7:02 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Its the throwout bearing I changed mine three time on my first gen 2003 v6 5spd trd access cab. One time was when I did the clutch at that time the flywheel was also chewed up, I think it was all related but not sure. after the third time it still made the noise but I just let it go because I got sick of taking my truck in. This time I bought an auto...
  6. Mar 28, 2012 at 11:51 PM
    rpking
    Roger
    Ohio
    yeah even in neutral
  7. Apr 2, 2012 at 3:51 PM
    Gyprat
    Gyprat Active Member
    2010 4 cyl, SR5, Manual
    Mine started making same noise. 38,000 miles and it's out of warranty. I wonder if Power train waranty covers the bearing replacement.
    The noise is getting loud. What a piece if shit I bought.:eek:
