Crimp connectors
Discussion in 'Audio & Video' started by primer, Mar 27, 2011.
  1. Mar 27, 2011 at 8:22 AM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    This isn't specific to A&V but I figured this is the forum that would have the most input and it certainly applies.
    I'm looking for advice on crimp connectors. I've used a variety of spade and bullet crimp connectors with frustrating results.
    I simply can't reliably crimp the connectors to a wire. (Insert "you're a wimp" comment here) I'm really not a complete wus. But regardless it shouldn't be that hard. I use my wire striper/cutter/crimper combo tool to crimp. It takes me several teeth gritting attempts to get the wire locked in. I see them used by others and can't imagine everyone puts up with this.
    Is there a particular brand of connector that works well? Is there a better tool to crimp with?
    Thanks
    TL
  2. Mar 27, 2011 at 9:30 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If I'm forced to use connections like that I typically strip close to double the amount of wire I'll need. Then I fold over the end about 75% back on itself. Then I stick that in the connector and crimp that in. It gives the terminal a lot more to hold onto.
  3. Mar 27, 2011 at 9:35 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I used tons of crimp connectors on my truck, as long as you use the correct crimp for the guage you are fine, I put 18g in a 12-10 crimp and it slipped out after being crimped
  4. Mar 27, 2011 at 9:40 AM
    primer
    T
    OK
    Thanks.
    That may be my problem. The wire I used was smaller than 18g. It's possible that doubling it would help. Or just getting the right sized connector. Sounds like there's not a specific tool or anything.
    Thanks again.
    TL
  5. Mar 27, 2011 at 2:48 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Solder. It makes a better connection.
  6. Mar 27, 2011 at 2:51 PM
    primer
    T
    OK
    Agreed. But it frustrates me that I can't make a crimp connector work.
  7. Mar 27, 2011 at 2:57 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Sometimes it's not always a good idea. Sometimes you want to be able to take the wires off every once in a while. But I agree for fixed usage it's the best for sure.
  8. Mar 27, 2011 at 2:57 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Maybe you need a better crimp tool.
  9. Mar 27, 2011 at 7:02 PM
    primer
    T
    OK
    That was my original thought. Which begs the question - do you recommend a particular crimp tool...
  10. Mar 27, 2011 at 7:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Crimped connections ARE suitable for automotive use - with all the attendant vibration.
    1. Use the right size crimp for the wire you're using
    2. Use a ratchet crimper. I THINK the one I use is 69555K62 from the following page:
    http://www.mcmaster.com/#wire-crimpers/=bmez15
  11. Mar 27, 2011 at 7:05 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    This, if a crimp must be used.
  12. Mar 27, 2011 at 7:06 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you can double the wire back - it means you're using too big a crimp connector for the wire.
  13. Mar 27, 2011 at 7:07 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  14. Mar 27, 2011 at 7:42 PM
    primer
    T
    OK
    I'll bet these would be good. Not sure I do this enough to warrant the cost.
    I'll bet this is good advice - and the source of my problem. I definitely had a lot of room around the wire and could have doubled it.
    This is what I've been using. As everyone has mentioned - I think my connectors are too large for my wire. NOTE edit - used to say too small - thanks bjmoose.
    Thanks all.
  15. Mar 27, 2011 at 7:48 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    I hope you're not using the 5 dollar tool from the auto parts store. Those suck. I have a klein crimper and a seperate klein stripper. Use them every day at work with no issues at all. I should have just spent the money and got the right tools a long time ago. Use the right tool and the correct terminal for each size wire and you should have no issues.
    Edit: Home Depot should have them both at a decent price. I want to say like 35 bucks for the crimper and 20 for the stripper I have.
    Edit: Here's the type of crimper I have: http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
    and stripper http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
  16. Mar 27, 2011 at 10:50 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm guessing you just misspoke here, but if you can double the wire back - it means the connectors are TOO BIG - (although the numeric wire gauge number would be lower - perhaps that's what you meant.)
    Don't mean to pick nits on a typo, but don't want a misunderstanding to slip through either.
  17. Mar 28, 2011 at 6:20 AM
    primer
    T
    OK
  18. Mar 28, 2011 at 6:22 AM
    primer
    T
    OK
    VERY good point. You are correct I just typed it wrong. I've edited the original post to avoid more confusion.
    Thanks
    TL
