Critique my build!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whatcouldgowrong, Mar 11, 2025.
  1. Mar 14, 2025 at 6:17 PM
    #41
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    When money is no factor...go all the way!
  2. Mar 14, 2025 at 10:33 PM
    #42
    Epic3rdgen
    Epic3rdgen Well-Known Member
    A-A-ron
    2016 ACab OR
    +2 TC LT Fabtech 6’’ bracket w/4link on 40’’ KM3-s Raceline Wheels
    I guess you would want to check out my build. I started out real easy. Than got on to this forum and dropped 100k I love these Toyotas. I just really enjoy my 2016. Good luck lets see pictures as you build.
  3. Mar 15, 2025 at 12:21 AM
    #43
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    0. Can’t critique your dream.
  4. Mar 15, 2025 at 12:23 AM
    #44
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Have you ever wheeled your rig?
  5. Mar 15, 2025 at 12:36 AM
    #45
    offroadguy651
    The North
    2023 TRDoffRoad
    Sorry didn’t see this before posting. Let me just laugh out loud!!!!
  6. Mar 15, 2025 at 7:15 AM
    #46
    CassiChloe
    CassiChloe Member
    Cassandra
    2020 SR5 access cab white 3.7
    Step side, aftermarket sound, remapped ecu
    If your primary goal is saving weight/adding power and not overlanding you’re going to be happier shaving than growing a beard. That means throwing steel away not gluing hair to your face. Your best is to glue hair to the top of your pistons as opposed to gluing hair onto your intake manifold, unless you plan on changing the intake manifold which was originally designed to work properly which means that you will also need to change timing in the event you decide to start shoving air into the intake manifold via super charger. It’s gonna get hairy because the original engine is designed to regard intake timing so that the intake bake remains open during the first 1/5 of the compression stroke. This forces stroked air into the intake manifold which ramps up boost pressure similar to a turbo charger. A lot of people out the magneson charger on and they complain “it’s not any faster is it just heavier” the answer is no.. fi doesn’t work with stock intake or timing.
  7. Mar 15, 2025 at 12:15 PM
    #47
    TheGrayNorthWest
    TheGrayNorthWest Well-Known Member
    I have always come to Tacoma World for informative information, but threads like these always make me think that with the introduction of a "best of" section, this site could also be an entertainment goldmine.
    BillF1564 likes this.
  8. Mar 15, 2025 at 1:07 PM
    #48
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    This is NOT the place to come for advice . . . . just saying.
    The best tires, wheels, suspension, etc. = what ever the poster runs.
    Plus I have seen people post some crazy ass shit on here.
    Entertainment . . . . absolutely.
    Veet-88 and Phlogiston like this.
  9. Mar 15, 2025 at 1:07 PM
    #49
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    meh on the pro charger, the stock tune has a low rev limit (due to your limited fuel system) Another guy already blew his engine with an aftermarket tune that didnt limit the rpm. Still also have the issue with the intake flap being a weak link.
  10. Mar 15, 2025 at 2:42 PM
    #50
    dryheat
    dryheat Well-Known Member
    "NEVER BEEN IN THE MUD" lmao
    majpooper and wood714[QUOTED] like this.
