Critique my possible 2010 OME 2" lift build.
Discussion in 'Suspension' started by Scott101, Mar 6, 2013.
  1. Mar 6, 2013 at 4:59 PM
    Scott101
    Scott101 [OP] Member
    So, here it goes: I currently have a 2010 Tacoma Access Cab base model 4X4 with a V6 and no TRD package. I currently have access to a garage/lift and would like to put 32” tires and a lift on it. I have been doing my research and just wanted to list my ideas for feedback and pose a few questions. I have been thinking about the following:
    Complete Old Man Emu Heavy load 2” lift kit. (Part No. OMETAC05HK)
    Total Chaos Upper Control Arms (Part No. TC-96504)
    Here come the questions:
    1.) What tire wheel combination would be best (6Lug)? I will be approx. 70/30 road/trail. Also, where would I buy said tires/wheels?
    2.) Would the larger tires require different gears in the differential?
    3.) The OME kit is “complete”, but is there anything else I would need to buy to install it?
    4.) Other than requiring an alignment, after the lift is installed, is there anything else I’m missing?
    Thanks in advance.
    Scott
  2. Mar 6, 2013 at 5:06 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You will get more than 2" of lift
  3. Mar 6, 2013 at 5:25 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    OZ is correct, that's the heavy setup for a bumper and winch, and the rear springs will give you way over 2" back there too.
    1 - Lots of options, what size are your stock rims?
    2 - Different gearing not needed for 32" tires.
    3 - I think it has everything needed for a nice suspension.
    4 - I don't think so.
  4. Mar 6, 2013 at 5:27 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    You'll need bushings for the leaf springs.....
  5. Mar 6, 2013 at 5:30 PM
    OZ-T
    Peter North
    British Columbia
    Depends where you purchase it
  6. Mar 8, 2013 at 10:02 AM
    Scott101
    Thanks for the info. I'm rotating the tires this weekend. As soon as I do I'll continue the discussion. (I assume by looking on the inside of the wheel is the only surefire way to tell the size of the wheel).
  7. Mar 9, 2013 at 4:51 PM
    Scott101
    Ok, so my tires are P245/75R16. I was looking at getting the the TOYO A/T II Tires which are P265R75R16 (32.65” diameter). The difference in width is .79”.
    1. Will this difference require wheel spacers?
    2. The sticky entitled “bjmoose installs full OME kit and rear brake lines” has the gentlemen installing new rear brake lines with his lift. Is this required?
    3. So, new tires will cause my speedometer to be off a bit. Is there a way to recalibrate it or am I always going to be doing it in my head?
  8. Mar 9, 2013 at 4:52 PM
    OZ-T
    Peter North
    British Columbia
    1) no
    2) no
    3) no
  9. Mar 17, 2013 at 2:39 PM
    Crusher
    Crusher How deep do you think that is?
    Greater YYJ
    06 DCLB TRD nekkid
    Debadged, Blacked out grille emblem, Alum headache rack & bed rails, OME 886 springs, OME Nitro's all around, Dakars, ARB Deluxe bull bar with Warn VR8000, leather front seats
    I have installed the complete OME kit, ARB bumper and winch.
    The 886 springs definitely gave me more lift than was expected.
    I agree with Oz, I ramped my truck at Westshore Spring and the rear lines are plenty long.
    The only problem I am having is a pretty good pull to the left, even after being to the Victoria stealership TWICE for alignment attempts.
    Not sure why I still have the pull. Metro said that was the best they could do, blaming the problems on the lift.
    Other than the alignment issue I am very happy with the kit, the Dakars in the rear are strong enough to haul my quad without squatting the truck down.
    I haven't had time to wheel it yet though, I've got a house and yard to maintain too. And a wife. ;-)
  10. Mar 29, 2013 at 5:56 PM
    Scott101
    Crusher, did you install UCAs with your lift. If not, do you think this would help the allignment issue?
  11. Mar 30, 2013 at 7:59 AM
    Crusher
    Greater YYJ
    06 DCLB TRD nekkid
    No I didn't install new uca's. yesterday I went to a local 4X4 shop to discuss the problem, they basically told me I picked the wrong shop to align. They have installed many of these kits and had no problems. I'll be taking it to the shop they recommended.
    I specifically asked if replacing the uca's would help, they said no.
    I'll post again after I have this other shop align it for me.
    Apparently the dealership techs don't like anything modified. At least here in Victoria. They would rather work on Grandma's Camry....
  12. Mar 30, 2013 at 8:01 AM
    Crusher
    Greater YYJ
    06 DCLB TRD nekkid
    Just re-read my previous post, don't know what I was thinking but the pull is to the right.
    At least it pulls me off the road...
  13. Mar 30, 2013 at 8:08 AM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    OP, if you only want 2" of lift consider the Iron Man lift (heard good things). With 2" of lift you should have no problems aligning with stock uca's.
