Crooked back axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacotuesday04, Dec 22, 2016.
  1. Dec 22, 2016 at 2:29 PM
    Tacotuesday04
    Tacotuesday04 [OP] Well-Known Member
    2017 white DCLB tacoma
    2" coil spacers in front, 1.5" lift blocks in rear with 285/75/r16s. Painfully stock.
    Hi guys I had my truck on a lift and the drivers side tire hangs about an inch and a half lower than the passenger. Is that normal?
  2. Dec 22, 2016 at 2:43 PM
    Tacotuesday04
    I just measured from there and it is more like 7/8 of an inch
  3. Dec 22, 2016 at 2:44 PM
    Tacotuesday04
    When on the ground it is only a little over a quarter inch
  4. Dec 22, 2016 at 2:45 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    need more info:
    how did you measure (from where to where specifically)
    how old are your springs
    etc
  5. Dec 22, 2016 at 2:49 PM
    Tacotuesday04
    From bumpstop on axle to bumpstop on frame and the springs have about 20,000 miles on them
  6. Dec 22, 2016 at 2:55 PM
    Tacotuesday04
    I have a 3 inch add a leaf with 1 inch blocks
  7. Dec 22, 2016 at 2:56 PM
    Tacotuesday04
  8. Dec 22, 2016 at 3:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Doesn't sound 'crooked' to me. Sounds more like you have more droop on one side than the other. Are the shocks maxed out? Are the shocks limiting down travel?
    FirstGen Jer likes this.
  9. Dec 22, 2016 at 3:17 PM
    Tacotuesday04
    That might be it, if so is that any concern?
  10. Dec 22, 2016 at 3:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If the shocks are the the limiting factor, yes, it'll ruin them. Dis mount each shock on one end (top or bottom, doesn't matter). Does it allow the axle to droop even further?
  11. Dec 22, 2016 at 3:51 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    From factory the shocks arent equal lengths. 7/8" would be normal
    Edit: if you have 4" of lift then what shocks are you using?
  12. Dec 22, 2016 at 4:37 PM
    Tacotuesday04
    They are fabtechs
  13. Dec 23, 2016 at 2:17 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  14. Dec 24, 2016 at 10:15 PM
    97ktstacco
    97ktstacco Member
    Ive had a few lifted yotas a 96, 03, 04 and my buddy has a 99. They all have a lean to them.. maybe wore out leaf springs or even ball joints. Check your struts too.
  15. Dec 25, 2016 at 7:21 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Thats called the taco lean. Caused by more weight on drivers side.
    mechanicjon likes this.
  16. Dec 25, 2016 at 11:53 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Right like devin said thats taco lean but the op's axle is hanging. I bet as tacodell mentioned above that the fabcrap shocks are of equal length thus causing the axle to hang crooked since the shock mounts are different side to side.
    OP are you sure you dont have a 3" block and 1" AAL? Just curious...
  17. Dec 26, 2016 at 6:09 PM
    Tacotuesday04
    no they are three inch add a leafs, because when I was done the back was sagging a bit so I made one inch blocks and installed them with the add a leafs to make it level
  18. Dec 26, 2016 at 6:14 PM
    Tacotuesday04
    the shocks are what is causing it, but I still have plenty of travel for what I need because where I live it's mud and snow I go through. so no worries about bottoming out shocks.
