crooked steering wheel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ron Knievel, May 11, 2015.
  1. May 11, 2015 at 7:59 PM
    Ron Knievel
    Ron Knievel [OP] Active Member
    is there an acceptable amount a steering wheel can be crooked and still be in spec?
    just got a new truck and i noticed on the highway the steering wheel is about a quarter inch lower on the right side. its just barely enough to notice, but it has started to bother me.
    it tracks perfectly fine and does not pull on way or the other at all.
    is that something that the dealer could straiten..or would it fall in to the category of "its within spec"?
    would the front end have to be realigned to straiten it perfectly, or is there any adjustment on the wheel itself?
    thanks
    ps this is my second tacoma like this. my first was way off from brand new, but it was just a work truck so i never bothered having it looked it.
  2. May 11, 2015 at 8:01 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    I'm confused by the "lower on the right side". You mean the whole column is lower? Or the steering wheel is tilted to the right?
  3. May 11, 2015 at 8:04 PM
    Ron Knievel
    the steering wheel is turned to the right when driving perfectly strait. the outer wheel is turned about 1/4 inches to the right if measured on the steering ring if that makes sense
  4. May 11, 2015 at 8:05 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    sounds normal due to the crown in the road.
  5. May 11, 2015 at 8:09 PM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Sounds normal. Now I was told by and old mechanic many years ago why all vehicles do that. I told him I put larger wheels and tires on my truck and it just ever so slightly pulled to the right on the highway. Even the steering well I had to apply just moderate pressure to keep it in the lane. Nothing drastic, mind you. But he told me all vehicles do that because incase you fall asleep at the wheel, for example, the vehicle will travel (right) away from oncoming traffic.
  6. May 11, 2015 at 8:14 PM
    Ron Knievel
    im not explaining it correctly i guess. the truck does not pull to the right. even if you let go of the wheel it goes perfectly strait...but while going perfectly strait the wheel is a few degrees turned to the right.
    is that normal to have the steering wheel cocked to the right even when going strait?
  7. May 11, 2015 at 8:17 PM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    I would say yes. If you don't have any wild steering problems its normal. The symmetry of the steering wheel must be annoying you the most. :)
  8. May 11, 2015 at 8:24 PM
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    Take it to the dealer with your concern. They can straighten/center your steering wheel as part of a front end alignment. I expect they can do that without changing the camber , toe, caster , off-set.
  9. May 11, 2015 at 8:39 PM
    jandrews
    '09 FourDubDee TRD OR
    Road crown if you're steering slightly toward center line. If you're steering slightly away (i.e. towards the shoulder) your alignment might be off.
  10. May 11, 2015 at 8:52 PM
    Ron Knievel
    i would think the alignment would be off it it pulled on way or the other.
    with no pulling in either direction and the steering wheel being very slightly turned when going strait, i would think the steering wheel is not adjusted to be strait when the wheels are all aligned.
    im just wondering if there is a certain degree spec it should fall into...like plus or minus 2 degrees either way, etc.
  11. May 11, 2015 at 8:53 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    My own personal experience has been, the straightness of the wheel depends upon two things; how critical an eye for straight the tech posesses, and how much he gives a crap about perfect straightness.
    They actually have a measurement for wheel straightness called "steer ahead". I have had techs line the wheel with the directional and wiper sticks on the column which are slightly off-center-left, when they should actually be lining it up with the bottom of the instrument cluster, which is true left-right plane. I have had to bring mine back a few times till they got this right.
    Have them redo it till it's satisfactory to your eye.
    NMTrailRider and chris4x4 like this.
  12. May 11, 2015 at 8:54 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Unless the wheel is off center by an obnoxious amount, a little is normal. Cross slopes of pavement have an effect on steering. Can't get away from it.
  13. May 11, 2015 at 8:54 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have had multiple alignments and had dealers attempt to straighten out wheel... Been a little off center to the right since I got the truck at 75k. Not the end of the world for me anyway
  14. May 11, 2015 at 8:58 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Some folks have the power to compensate for the imperfection...others it'll send down the road to psycotic OCD fits to the point they are driving down the road in a sawtooth pattern. That would be me.
  15. May 11, 2015 at 9:06 PM
    Ron Knievel
    i kept looking down at the wheel and trying to guess the degree it was off that i didnt notice i was chewing the side of my tongue off until i tasted blood.
    Ridgerunner likes this.
  16. May 11, 2015 at 9:07 PM
    memario1214
    Colton
    Missoula, MT
    Haha! Every once in a while on a long drive I will notice it, but for the most part I just let it be. I suppose it could always be worse :)
  17. May 11, 2015 at 9:07 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Yup haha it's a sick club!
  18. May 11, 2015 at 9:12 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    You're one of the lucky ones! If my wheel isn't deadon, I apparently obsess with it to the point of not hearing my girl talking to me. Once she blurted out "would you take it in and fix the wheel-you're driving me nuts!" I had no idea.
  19. May 11, 2015 at 9:12 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    you can get it zeroed, to where it is back to 0°.......I get mine done about twice a year, because of my OCD.
  20. May 11, 2015 at 9:14 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    If it bothers you enough, then it should be corrected under warranty. I bought my `04 new with a cocked steering wheel and they fixed it.
