Crooked steering wheel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reinhardtius, Aug 16, 2019.
  1. Aug 16, 2019 at 5:40 AM
    Reinhardtius
    Reinhardtius [OP] Well-Known Member
    07 Base 2.7L 5SP
    Hey Folks
    I had a mechanic remove a spacer lift kit the other day and now the steering wheel is turned a little to the right in order to go straight down the road. The diff drop kit is still installed, and I will take that out myself today (he forgot to take it out). Will removing the diff drop kit and the alignment I have scheduled for Monday address this?
    Thanks
  2. Aug 16, 2019 at 5:45 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Tell them when you get an alignment- "the steering wheel is off a ----- of an inch to the right" . They will adjust the tie rod ends on one side more than the other to center the wheel.
    Reinhardtius[OP] likes this.
  3. Aug 16, 2019 at 5:51 AM
    Reinhardtius
    07 Base 2.7L 5SP
  4. Aug 16, 2019 at 11:53 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    The steering wheel should be centered and locked in place, they have a tool holds the steering wheel centered while the toe is adjusted.
    TnShooter likes this.
  5. Aug 16, 2019 at 12:13 PM
    DougSD
    DougSD Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    Any competent shop should always center the wheel when they align a vehicle
    joeyv141, 06Tacooo and TnShooter like this.
  6. Aug 16, 2019 at 1:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This ^^^
  7. Aug 16, 2019 at 2:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hope you arent driving too far as toe camber and caster after a drastic lift change, change a LOT.
  8. Aug 16, 2019 at 2:25 PM
    Reinhardtius
    07 Base 2.7L 5SP
    I think I have driven the truck 50 miles. I seriously doubt that I am destroying my tires. But then again, if I did, THAT WOULD GIVE ME AN EXCUSE TO GET SOME NEW MICHELIN LTX M/S's!!!!! HHHMMM!!!!
    06Tacooo likes this.
  9. Aug 16, 2019 at 6:25 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Alignment will fix this, its normal to need a alignment after installing/uninstalling spacers, if you paid for a alignment they should correct it for free if you didnt you should pay for one now.
