Cross Check Before Purchase: Method Race Wheels
Discussion in 'Wheels & Tires' started by JMWolf96, May 25, 2013.
  1. May 25, 2013 at 9:46 AM
    JMWolf96
    JMWolf96 [OP] Active Member
    Jim
    Severn, MD
    11 Tacoma TRD Sport
    Guys,
    I am pretty sure I am correct but please cross check me before I purchase:
    - Currently running 17x9 KMC XD Addicts with -12mm offset, BS is 4.5" (I think)
    - Switching to Method "Standard" Race Wheels in 17x9 with -12mm offset and 4.5" BS
    - Bolt pattern is 6x5.5 and I will run the same 265/70/17 Nitto Terras that I am running now.
    Pretty sure these will fit with no issues, but just wanted a sanity check before I drop the coin.
    Thanks guys!
    Jim
  2. May 28, 2013 at 7:16 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Just make sure the center-bore will accommodate the Tacoma's 106mm hub.
  3. Dec 25, 2015 at 4:33 PM
    canecorso
    canecorso Well-Known Member
    saint john new Brunswick canada
    2015 dclb
    what if the center bore is 108.?
  4. Jan 2, 2016 at 6:34 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I recently purchased wheels with a center bore of 108. I used an ET splined lugnut to get them centered on the lugs so they wouldn't cause vibrations.
