Cross Threaded a Seat Bolt.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BKinzey, Aug 2, 2021.
  1. Aug 2, 2021 at 7:37 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Installing seat lifters. Caught it just a little too late. :annoyed::bananadead:
    Now the nut is putzed. Anybody replace these? How?
    The only option I can think of is to drillout the threads of the body nut and use a lock nut with a longer bolt. :(
  2. Aug 2, 2021 at 7:44 PM
    2005TRD
    2005TRD Active Member
    capital district NY
    05 TRD 6spd BSP 3"
    Tap
    Torspd, 12TRDTacoma and Mark77 like this.
  3. Aug 2, 2021 at 7:44 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I second the tap, if you know the correct pitch, you can fix the threads.
    Key-Rei and 12TRDTacoma like this.
  4. Aug 2, 2021 at 7:51 PM
    2005TRD
    capital district NY
    05 TRD 6spd BSP 3"
    I think it's a 10mm fine
    12TRDTacoma likes this.
  5. Aug 2, 2021 at 7:54 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Turn it more. Free loctite
    Jojee117, mtip, 6 gearT444E and 7 others like this.
  6. Aug 2, 2021 at 7:55 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Do the bolt holes to through the floor boards, like can you see the nut from under the vehicle? If so run either the bolt or correct tap up threw the nut using the good threads at the bottom to safely start.
    whatstcp likes this.
  7. Aug 2, 2021 at 8:09 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Use a thread chaser. A tap is for cutting threads. A chaser is for restoring them.
  8. Aug 2, 2021 at 8:33 PM
    BKinzey
    Beauford
    Hollywierd, CA
    From looking at the nut from underneath there is some form of a plug. Not sure it can be removed or how. I think it would interfere with a thread chaser.
  9. Aug 2, 2021 at 8:37 PM
    shaeff
    Hudson Valley, NY
    If it won’t interfere with a tap, it won’t interfere with a chaser. :)
  10. Aug 2, 2021 at 9:53 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve never had much luck with thread chasers. Except if the threads are still very good and only dirty. Since the hole is damaged by cross threading, the threads are damaged but not a lost cause. You could somewhat repair the hole with a tap. Since there’s a plug at the bottom, the metal shavings are going to stay in the hole instead of falling out the bottom. You’ll have to be very patient. Turn the tap, blow out the metal shavings, repeat. Tapex does wonders. You could do it with a starter tap, then a bottom tap. Then look closely at the threads. If it’s too far gone, trying to tighten a bolt in it will just rip out the remaining threads. If you’re lucky a bolt will tighten. If not a helicoil thread repair insert is next. If you’ve never done it, get help. Or tap it out to the next larger bolt that’ll fit the seat. I’d stay with fine thread type.
    Use good quality bolts. Seat bolts feel heavy because they’re dense and strong. In the event of an accident, you don’t want to go flying into the windshield because the cheap bolts you got broke.
    Key-Rei, 12TRDTacoma and Dm93 like this.
  11. Aug 2, 2021 at 10:00 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I’d try a plug tap if it isn’t a through hole.
  12. Aug 2, 2021 at 10:40 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Clean up the threads with a tap or a chase. If they are seriously putzed, put a heli-coil in. Remember to use some cutting fluid with the tap.
    As a side note, be sure you are using at least a 10.9 bolt and preferably a 12.9. I have seen 8.8 or lower class bolts used on jackers which is a terrible idea for a safety system. I know lots of people like the jackers, but using a spacer in a single shear mount isn’t a great idea for maintaining rigidity.
    Torspd likes this.
  13. Aug 2, 2021 at 10:48 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Cross threading is as good as locktite one time. Just leave it?
  14. Aug 3, 2021 at 4:30 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Not the only option, but, the fastest, easiest and cheapest (if you don't already have taps and dies). it will work as well as a thread restoration, and know one will no except you.
  15. Aug 3, 2021 at 8:50 PM
    BKinzey
    Beauford
    Hollywierd, CA
    It's my daily driver and I didn't feel it was a good idea to drive around with 3 bolts so I put the original bolt back in. After several tries I couldn't get the original threads to catch and ended up torquing it in anyway.
    Hopefully somebody who has replaced the seat nut will see this and pipe up.
    Thanks for the replies.
  16. Aug 3, 2021 at 9:15 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I'm pretty sure it's tack welded to the bottom of the cab. Grind it off and weld on a new nut, problem solved.
  17. Aug 3, 2021 at 9:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OMG. I have no words.
    Torspd, TegoTaco and 6 gearT444E like this.
  18. Aug 4, 2021 at 5:06 AM
    jbrnigan
    Midwest
    Neither do I ....... not understate the obvious, as I'm sure you are aware; your inboard seat belt (the buckle) anchors on the seat frame making the seat attaching bolts an integral part of the seat belt system. What you have a seat bolt that likely has no more holding power than if you had driven it back into the hole with hammer.
    Grossomotto likes this.
  19. Aug 4, 2021 at 8:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Is it a rear of the seat bolt that goes through to the bottom of the body? If so, longer bolt and extra nut n call it good.
  20. Aug 4, 2021 at 1:23 PM
    Crashmo
    Crashmo Well-Known Member
    Captain Dude
    Portland
    Was 03 TRD, Now 07 TRD
    Brush guard and Bed Storage and Karr Alarm.
    Give it a couple of ugga duggas. Cross threading is free loctite. ;)
