Cross threaded differential fill plug!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tovar28, Aug 25, 2015.
  1. Jun 23, 2017 at 7:18 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    I did the same, I took it to a mechanic I didn't want to cause anymore damage then I already did, let the pros fix it its worth spending a few dollars wasn't that much
  2. Aug 25, 2017 at 12:38 PM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    So I thought I'd do a followup for anybody that this happens too. I overtightened my fill plug. Got the old one out and bought a new one. Re tapped the threads (Marlin Crawler). Trick here I learned is to fill the gaps with loads of grease to catch shavings that may occur. Worked great, came out with a few. New plug threaded great but still had a slight leak. After multi-state trip I took a look to see how much had leaked out. Lost about .2-.3/qt. Bought another qt and put teflon tape around threads this time and cleaned cover as much as possible. Coated with flour to make it easier to tell if anything was leaking. So far after 1 week and about 100 miles in 100+ degree temp all is good. No leaks.
    skytower and PzTank like this.
  3. Aug 6, 2019 at 4:37 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    You were leaking out of the fill plug or drain plug?
  4. Aug 6, 2019 at 4:53 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Never had an issue not using a torque wrench on any drain or fill plug....
    I think it’s been mentioned here a few times but you use a 3/8 ratchet,, choke up to the socket and get it as tight as you can.
    racerX969 likes this.
  5. Aug 6, 2019 at 4:55 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    That's what I'll be doing from now on. Last time I torqued my transfer case drain plug I overtightened it just a bit and have a tiny leak. Guess my torque wrench was slightly out of spec.
    PzTank[QUOTED] likes this.
  6. Aug 6, 2019 at 6:49 PM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Drain plug. I actually followed up again with some gasket sealer and have had no leaks for about 6k miles so far.
  7. Aug 6, 2019 at 7:16 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Roger that. I might try the teflon tape first to see how that works. Which gasket sealer did you use?
  8. Aug 6, 2019 at 10:42 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I wouldn't use teflon tape, you don't want that clogging any orifice or passage in the differential. Better off going with a PFTE tread sealant, such as this.
    Marc70 likes this.
  9. Aug 6, 2019 at 11:21 PM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    never been so scared to change diff fluid in a truck before reading this.
    Marc70 and TheDevilYouLove like this.
  10. Aug 6, 2019 at 11:22 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It's a 15 minute job bub
  11. Aug 6, 2019 at 11:23 PM
    cromag27
    phx-ish
    if that. i just don’t know why tacomas would have an issue with stripped threads? never been a concern with my f150. is it something about tacomas or user error?
  12. Aug 6, 2019 at 11:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The drain plug can become tough to remove, as long as you have a welder it's not an issue. That 10MM hex plug was designed by satan.
    PzTank likes this.
  13. Aug 7, 2019 at 5:17 AM
    PzTank
    Above the Notches
    TheDevilYouLove likes this.
  14. Aug 7, 2019 at 5:26 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Well I wouldn't have used so much of the tape that it was hanging into the diff ... but I was worried about the tape potentially having issues with the heat. Thanks for the link to the thread sealant. Just ordered. :spending:
    6 gearT444E[QUOTED] likes this.
  15. Aug 7, 2019 at 5:47 AM
    #35
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Just curious what size tap is needed to chase the existing threads on the diff drain/fill holes?
  16. Aug 7, 2019 at 2:53 PM
    #36
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    This...
  17. Aug 17, 2020 at 3:10 PM
    #37
    czotie
    czotie Dang Ol' TacoBio
    Zote
    California
    2001 Silver Tacoma 4x4 Xtra Cab
    Bilstein 5100's Firestone Riderites Deckplate Mod & AEM Aisin Clutch plate Luk Flywheel Timken bearings Marlin Crawler shifter bushing GTA CarKit Gentex 453
    I'll be doing this next weekend.
    I bought a new torque wrench because my other new cheapo from scAmazon broke a bolt on my transmission shifter assembly (always the last one you put on.). Finished front diff, transfer case, and was putting in the plug on the rear diff and it wouldn't snug down... I wasn't cranking it very hard either. Everything was set to spec. It's not leaking at the moment...
    I went to the dealership for new drain and fill plugs and gaskets/washers before I started.. Should have looked in the bag when I walked out. Guy didn't give me a rear diff drain plug replacement and I didn't realize till I had drained so I went with the old one and a new gasket/washer. Truck is 20 years old and 235K miles... decided to go with the old one and a new gasket...
    I didn't hear it snap, I didn't hear it break... I just got it to the point I'd want to torque it to spec, did so and it just kept spinning. Tipped me off when the mother would spin and get tighter and then loosen a bit and then get tighter again...
    Damn shame... always something. :sadviolin:
  18. Aug 17, 2020 at 7:00 PM
    #38
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    I ended up just grabbing some liquid gasket and it’s not leaked since.
  19. Aug 18, 2020 at 8:56 AM
    #39
    czotie
    Zote
    California
    Thanks FFMast, good call.:drunk:
    Just ordered some Permatex High Temp liquid gasket, (-54 - 343°C). If I can't thread the replacement on easily and I have to tap or re-thread I'll try some of that first & with the tapped thread. Providing I can get the plug off to begin with. :annoyed:
  20. Aug 18, 2020 at 10:46 AM
    #40
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    I did do a re-thread with the next size up plug. Got my tap from Marlin Crawler. I greased it up real good first to catch shavings and that worked real well. Then I put the high temp gasket sealer on there. I’ll try to find the tap and let you know what size I used.
