CROSS THREADED DRAIN PLUG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kenroseb, Mar 26, 2020.
  1. Mar 26, 2020 at 9:16 AM
    kenroseb
    kenroseb [OP] Member
    2015 Red Toyota Tacoma 4x4
    Alright so... the one time I don't change my own oil, someone cross threaded my drain plug on my oil pan. I don't even want to take it back there to get it fixed because if they can't even change the oil, I don't want them repairing it either lol. What's the best way I can fix this at home. Would you recommend re-threading the plug or just buying an entire new pan? I will have to do another oil change regardless. Some have said I could get lucky and it won't need to be replaced because the cross thread will still hold the oil, but I have been noticing a tiny leak every now and then. Thanks!
  2. Mar 26, 2020 at 9:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Tap it one size bigger? Other than that buy a new pan.
    BillsSR5 and Plain Jane Taco like this.
  3. Mar 26, 2020 at 9:21 AM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
  4. Mar 26, 2020 at 9:22 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  5. Mar 26, 2020 at 9:24 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I agree. Just throw a new pan on it. And odds are it's not cross threaded. It's probably been over torqued and blew out the threads.
    Blockhead and Tttacodan like this.
  6. Mar 26, 2020 at 9:24 AM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    They sell oversized drain plugs for this exact problem. It's a tempting fix that might get you by for a couple of services, but replacing the pan is really the only way to go.
    Blockhead likes this.
  7. Mar 26, 2020 at 9:24 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Just replace the lower oil pan and and see if they would reimburse you for parts and oil(unless you have something clean to recover it and reuse it).
  8. Mar 26, 2020 at 9:34 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Damn, that’s about the only both cheap and easy to install part on a Tacoma. Everything else costs $$$$ or is a motha to install. Yeh definitely replace the pan.
    Sterling_vH111 likes this.
  9. Mar 26, 2020 at 9:35 AM
    BEE-ROCK
    Brock
    Dallas, TX
    No gasket either. Pan is sealed with Toyota FIPG. The link I posted above is the correct pan.
  10. Mar 26, 2020 at 9:37 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    Monkeybutt2000 and Naveronski like this.
  11. Mar 26, 2020 at 9:38 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    You could try a self-tapping drain plug as a temp solution. I have used them with mostly good results. Worst case is it will leak and alert you to "time to put a new pan on."
  12. Mar 26, 2020 at 9:38 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    mac84 likes this.
  13. Mar 26, 2020 at 9:42 AM
    kenroseb
    Thanks everyone, I'll just replace the pan since it's so cheap. Plus, don't want to deal with a temp fix and have it blow out again. :mad:
  14. Mar 26, 2020 at 2:42 PM
    Waasheem
    Waasheem
    2007 xrunner
  15. Mar 26, 2020 at 3:35 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I would suggest reading a shit ton of reviews on fumoto valves outside of TW before deciding to use one. Many rave reviews and many complaints about leaking and valves opening after being struck by brush. It’s definitely not full proof.
    Skyway likes this.
  16. Mar 26, 2020 at 3:41 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    retap to bigger size would be easiest
  17. Mar 26, 2020 at 5:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe the drain plug is m12 x 1.25
    You can try on over sized plug if you want?
    I’d probably try it.
    I would thread the new over sized plug in to just before it seats against the pan.
    Then back the plug out, pour in a cheap quart or 5w-30 to flush any metal shavings created by the new oversized plug. (You could use the old oil also?)
    Finally thread the new over sized plug in, pour in some oil and hope for the best.
    The Torque Spec. On the drain plug is 30 ft/lb IIRC?
    It’s your call on how tight you want it.
    If it doesn’t work, replace the pan.
  18. Mar 26, 2020 at 5:30 PM
    Waasheem
    Waasheem
    2007 xrunner
    This is what keeps me from getting one. They do have a plastic thing to keep it from opening. Just my luck, I can see road debris hitting it just right to break the plastic off, then another hitting it just right to open the valve leaving me stranded in a bad neighborhood with no oil in the engine, no way to reach under to close the valve.
    TacoTRD78 likes this.
  19. Mar 26, 2020 at 5:38 PM
    Muddinfun
    Muddinfun Well-Known Member
    1st oil change after installing self tapping oversize drain plug.
    dawgn86, Jimmyh, Skyway and 2 others like this.
  20. Mar 27, 2020 at 12:02 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Miniature hose clamp is the way to go. My valve is going on seven years. It's never leaked and never knocked loose. I have an EZValve and Fumoto; prefer the EZValve because the inside diameter is larger, enabling for quicker draining. Fumoto is on wife's RX350. Both have the hose clamp to keep the little handle from accidentally opening.
    Blockhead and Monkeybutt2000 like this.
