Cross Threaded Spark Plug Repair?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ProForce, Aug 8, 2018.
  1. Oct 14, 2018 at 9:57 AM
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Yeah I see that too, weird.
  2. Oct 14, 2018 at 10:02 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Kroil.........or the Seafoam Creep is good schidt..........
    get some before you need it !
  3. Oct 18, 2018 at 11:32 AM
    bhotrod
    bhotrod Member
    b
    UTAH
    05 4x4 SPORT TRD
    Yeah that's just a little bit of oil not an o-ring, but your right it does look like that. Is the Deep Creep Seafoam different from the standard Seafoam? I have the standard one. This thing is a bitch. I have been searching online, but I haven't found schidt yet..
  4. Oct 18, 2018 at 12:35 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Deep Creep by Seafoam is a penetrating oil...completely different from Seafoam in the red & white can, the latter of which is a fuel/oil additive.
    Cheers, jeff
  5. Oct 18, 2018 at 12:46 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    it sure looks like some sort of o ring wedged down under the left side of the plug and looping over the right side.
    Who did the last plug change?
    Definitely looks like something that’s not supposed to be there and could be preventing full seating of your socket.
    Alexely999 and michael roberts like this.
  6. Oct 18, 2018 at 9:52 PM
    jepho
    jepho Active Member
    jeff
    Cut a notch in your socket with a grinder and zip disk so it resembles a socket used for removing o2 sensors (remove 2 out of the 6 sides). Slide the two sides you cut out down the narrow side where the spark plug is closest to the tube and loosen.
  7. Oct 19, 2018 at 7:49 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    *mind blown*
  8. Oct 19, 2018 at 7:57 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Biscuits likes this.
  9. Oct 20, 2018 at 3:58 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Don’t leave us hanging OP, did you get the plug out ok? :fingerscrossed:
  10. Oct 20, 2018 at 6:43 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    These guys have got it.. that rubber thing is the seal from the bottom of the ignition coil boot. Its stuck on the porcelin and preventing the socket from getting down on the plug. Get a curved dentist pick and pull it out, then the socket should slide on all the way
  11. Oct 20, 2018 at 5:50 PM
    ProForce
    ProForce [OP] IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Haven't tried yet lol. I bought a new car as a daily so the truck has been parked for a little bit. Making slow repairs as needed to it and its on my list. Tomorrow is brakes, then i need TC cam tab gussets because i sheered mine off on the last trip. Then the plug will be after that.
  12. Oct 22, 2018 at 1:51 AM
    bhotrod
    bhotrod Member
    b
    UTAH
    05 4x4 SPORT TRD
    Negative. I haven't gotten it out yet. It's definitely not a rubber o ring. That is a little oil. I will take another picture.
  13. Oct 22, 2018 at 6:35 AM
    PzTank
    Above the Notches
    Just to be clear, what I see in your original pic is a backwards C shaped thing, wrapping the right side of the spark plug and disappearing under the plug at about the 11:30 and 5:30 positions.
    If it is an oring, it would explain why you can’t get your socket seated - the plug might be cross threaded and askew..
  14. Oct 22, 2018 at 10:34 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Try grinding down the outside of your socket until it fits on the plug all the way.
  15. Oct 22, 2018 at 11:07 AM
    #35
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I think you are right after I enlarged the pic. Good eye!
  16. Oct 26, 2018 at 5:56 PM
    #36
    bhotrod
    bhotrod Member
    b
    UTAH
    05 4x4 SPORT TRD
    So I FINALLY was able to remove the plug. I ordered a thin wall spark plug socket from AMAZON.com and it worked. There wasn't an o-ring, or anything like that. There was a tiny bit of oil in there and the reflection is what gave off the look of an o-ring. It wasn't cross threaded either. I don't know what the ..... happened. Thanks for all your comments and help. I appreciate it.
