Cross threaded spark plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hotrod53, Nov 1, 2023.
  1. Nov 1, 2023 at 8:58 AM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    My son who lives 22 hours away cross threaded a new spark plug in his 21 V6 Tacoma, and the plug won’t come out.
    It sounds to me like he’s going to have to have it towed and the intake and head pulled. Anyone have experience with this?
  2. Nov 1, 2023 at 9:29 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    New plugs on a 2021 ? ... but why.
    Phlogiston, drizzoh and shakerhood like this.
  3. Nov 1, 2023 at 9:34 AM
    hotrod53
    Lynd
    Pittsburgh, PA
    Assuming that the originals aren’t iridium and he has more than 30k on it.
  4. Nov 1, 2023 at 9:35 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Not on a Tacoma but its pretty common on 4.6/5.4 Fords. Not sure what options are available for our trucks but look into either a helicoil or timesert if the threads can't be salvaged. These can be installed without removing the head. In fact if you have a local shop the deals with Mustangs they probably have experience with installing them and may be a good place to go.
    Big tall dave likes this.
  5. Nov 1, 2023 at 9:37 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    oddly this I my reoccurring nightmare.
    can he use a flashlight and mirror to look at it? it is indeed skewed and cattywompused? I have had some scary tight sparkplugs on my Toyotas. last time, I called my mechanic and he told me I was already past point of no return and to simply crank it off of there. it was kinda galled or something and the new plug went right in smooth as silk.
    AusBerg and Big tall dave like this.
  6. Nov 1, 2023 at 9:40 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Sound advice right here.
    AusBerg likes this.
  7. Nov 1, 2023 at 9:45 AM
    tcjacado
    tcjacado Well-Known Member
    Check this link, a heli coil may be able to save a expensive trip to the dealership.
    https://www.google.com/search?q=helicoil+kit+spark+plug+tacomaworld&client=ms-android-tmus-us-revc&sca_esv=578522338&sxsrf=AM9HkKnXWUWBgkxH-qxfcN3wUkBbzdi_Dg:1698856996632&ei=JIBCZY6PJrehptQP8eGukA0&oq=helicoil+kit+spark+plug+tacomaworld&gs_lp=EhNtb2JpbGUtZ3dzLXdpei1zZXJwIiNoZWxpY29pbCBraXQgc3BhcmsgcGx1ZyB0YWNvbWF3b3JsZDIFEAAYogQyBRAAGKIEMgUQABiiBDIFEAAYogRI6lZQvAtYgDVwAHgAkAEAmAH5AaABlROqAQUwLjcuNbgBA8gBAPgBAcICCBAAGKIEGLADwgILEAAYiQUYogQYsAPCAggQABiJBRiiBMICBRAhGKsCwgIEECEYCuIDBBgBIEGIBgGQBgQ&sclient=mobile-gws-wiz-serp
  8. Nov 1, 2023 at 9:48 AM
    Tacoma Mike
    Southern Maine
    Yeup.
    Not a pretty situation.
    You are talking thousands of dollars and more than likely a new head.
    It’s a labor intensive repair.
    Is he still making payments?
    Your only shot is what tc mentioned above.
    But, playing with aluminum inside a cyl needs lots of cleaning to get it all out.
    I am sorry..
  9. Nov 1, 2023 at 11:00 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The factory V6 spark plugs are not recommended for change until 60K.
  10. Nov 1, 2023 at 11:31 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    There are thread-serts specifically for spark plug threads. It usually comes as a kit. I’ve had good results with them.
    I wouldn’t use an actual heli coil on a spark plug.
    Northerntaco69 and ridefreak like this.
  11. Nov 1, 2023 at 11:37 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I wouldn’t do one of those thread repair kits on the head that is installed. The obstacles in the way created a very high chance of jogging up the install, and the possibility of debris and shavings entering the chamber is very high
    ridefreak likes this.
  12. Nov 1, 2023 at 1:59 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this is what I was wondering, I would think the risk of getting a metal shaving in the head is high, and very likely unnoticed.
    risk and reward
    shakerhood likes this.
  13. Nov 1, 2023 at 2:09 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    another vote for the timesert kit... doesn't have a tang like the helicoil that you could loose down the hole.
  14. Nov 1, 2023 at 2:19 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Repair is the last resort, you gotta be sure it actually needs it first. Are you talking it started fine, turn or two with fingers and then got tight or dropped in the hole and hit it with an impact?
    If it just got a bit tight but otherwise started fine it's probably just carbon buildup, should be fine to remove and retry.
  15. Nov 1, 2023 at 2:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the plug is spinning, but is stuck in the head.
    The valve cover is coming off at a minimum.
    You have to get the plug out. And there isn’t an easy way to get it out. Even when the valve cover is off, it will be a pain to out. If you can get the plug out, you might as well give it a go with Time-Sert or Helicoil. Worst case, the head is coming off anyways.
    Rock Lobster, shakerhood and tcjacado like this.
  16. Nov 1, 2023 at 2:56 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Why was he messing with spark plugs on a 2021 ? They are good for 60k miles. Some things you’re better off letting the dealership do.
    Bigmatt503 likes this.
  17. Nov 2, 2023 at 6:13 AM
    lbhsbz
    lbhsbz Well-Known Member
    Get a bigger breaker bar, either unscrew it or break it off....at this point, those are the 2 options. If it breaks off, the head needs to come off.
    If the head comes off, depending on how bad he boogered it up, a machine shop may be able to extract it and install an insert.
    If he can get it out, I'd guess it bound up on the first 3 or 4 threads and the rest of the threads are still fine. There is a tool called "back tap"...sort of an expanding tap / chaser that you can drop in the hole, adjust/expand out to engage in the remaining good threads at the bottom of the hole, then unscrew it to clean up the damaged top threads. https://www.summitracing.com/parts/...bjcz7IfzWwIRjl-EHBYIOW9VvWcxQihhoCi4wQAvD_BwE Use grease on the tool to catch the aluminum chips.
    I wouldn't be too concerned with small chips falling in the cylinder...they'll blow right out the exhaust. None of them should be physically bigger than the thickness of the headgasket so they won't get smashed or cause any damage....I'd rotate the engine over by hand through a couple revolutions just to make sure before hitting the key, just to be safe.
    Toy4me likes this.
  18. Nov 2, 2023 at 6:31 AM
    545
    545 Well-Known Member
    2015 Access Cab
    It’s gonna cost some time and money, or lots of money if a shop does it
    First off, get the plug out. It’s gotta come out one way or the other. Last one I did snapped so I had to pull the head and send it to the machine shop, he couldn’t get it out either, so he milled it out and put an insert. Timesert I think. Factory plug. And yet I still bought another Ford after that.
    If it doesn’t break, should be fixable without pulling the head. I suppose pulling it would be better but I wouldn’t bother-
    This is a somewhat common issue in the auto world, it happens. It sucks but it’s fixable.
  19. Nov 2, 2023 at 6:34 AM
    545
    2015 Access Cab
    Yeah this
    Although you should have lots of good threads left if you just try a back tap
  20. Nov 2, 2023 at 7:16 AM
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    Does it run? If it's not leaking compression through the threads, why not just leave it in for another 30K or so? I'm not a tech, but this was my first thought.
