Cross threaded spark plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hotrod53, Nov 1, 2023.
  1. Nov 2, 2023 at 7:39 AM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Remove the plug with a back and forth motion, i.e. tighten and loosen in small increments. If the threads are damaged run the spark plug thread tap and the key from getting metal shavings in the cylinder is use lots of grease on the the tap. I have done this many times with no issues. Good luck
    Big tall dave likes this.
  2. Nov 2, 2023 at 10:09 AM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Doesnt even sound like it needed new spark plugs. I still have the originals with 110k miles on them.
    Bigmatt503 likes this.
  3. Nov 2, 2023 at 2:53 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I’ve used a few spark plug Heli-coil’s in the past (not on my Tacoma *knock on wood/head*) and I’ve found that greasing the drill bit and tap along with an air hose constantly blasting in through an open valve and out the spark plug hole does a great job of keeping the shavings out of the cylinder (Verified with a borescope)
    I have no problems or concerns using them, even on high compression motorcycles engines. You just gotta weigh the pros and cons of Heli-coils vs removing the head (regarding risk, cost, time, PITA factor, etc)
    tcjacado likes this.
  4. Nov 25, 2023 at 10:54 AM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Update…. and first let me say this is the son with the brains and not the mechanical ability , and he lives 22 hours away!
    It turns out the rubber insert in the spark plug socket came out and got wedged between the plug and the head, he actually wasn’t over the top of the plug when it was spinning. He enlisted help from a friend with a bore scope and they realized that it was ever so slightly cross threaded and stuck. They got the rubber piece out, then the plug, then got it in straight with none the worst, but that’s not the end.
    Then the truck wouldn’t start! He fiddled around with it for 3 days, sometimes it would start, sometimes not. Turns out, he removed the plug from what he described as the cam position sensor. When he plugged it back in, it didn’t click in and was sometimes in, sometime not. When it didn’t make contact, the computer shut it down. Reseat the plug and it’s back up and running normally again.
    SmoPo16, soundman98 and Chew like this.
  5. Nov 25, 2023 at 11:07 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Good on him for getting it sorted
  6. Nov 25, 2023 at 11:23 AM
    Russ68
    Russ68 Member
    Wisconsin
    2021 TRD Off Road
    My F350 with the 6.2 snapped a plug in the head. That’s a cab-off, engine out, heads to machine shop $5K in labor cost alone ordeal. THAT’s why you change plugs really early (Ford) or, in the case of Toyota @60K miles.
