Crossed 130K mi on my 2012 4.0L Taco.....any addl maintanance items to take care of?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mitchbuck, Feb 26, 2018.
  1. Feb 26, 2018 at 6:52 AM
    mitchbuck
    mitchbuck [OP] Well-Known Member
    Cape Cod
    12 Taco 2xCab SR5
    I just recently crossed 130K miles on my 2012 Double Cab Tacoma 4x4 with the 4.0L engine that I bought new and I am wondering if there are any maintenance items that I should take care of in the near or near distant future? I do my own maintenance and replace oil/filter/air filter every 5K miles or so. At 115K miles I replaced spark plugs, serpentine belt, F & R differential oil, transmission oil, transfer case oil, and greased propeller shaft. My battery, tires, and brakes have all been replaced in the last 2 years. I think that I'm up to date on everything, but am I missing anything or anything that I should keep an eye on? Thanks in advance
    JimboAnz likes this.
  2. Feb 26, 2018 at 6:56 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    maybe brake fluid flush, and power steering fluid flush, other than that, looks like a good list. I just crossed over 100K so I am right there with ya :thumbsup:
    gthupman likes this.
  3. Feb 26, 2018 at 6:59 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    sounds like you're up on it......
    coolant flush........new hoses.......thermostat ?
    flush/bleed brake system.....along with power steering fluid (AT fluid)
    dump a can of Seafoam in fuel every so often.....? I do.......
  4. Feb 26, 2018 at 8:42 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Plugs should be every 30k miles
  5. Feb 26, 2018 at 9:57 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    :bikewheelie2:Italian tune up
  6. Feb 26, 2018 at 10:09 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP you are good man.
    About the only thing would be coolant, brake fluid and PS fluid, but the bulk of it you have done proper!
  7. Feb 26, 2018 at 12:06 PM
    mitchbuck
    Cape Cod
    12 Taco 2xCab SR5
    Cool thanks for all the input and I'll put steering/brake/coolant flushings on the list. I do put a bottle of the Lucas fuel injector cleaner in every few months. Does the timing chain need to be checked/changed at all or ever?
  8. Feb 26, 2018 at 1:12 PM
    Armed in Utah
    2003 Lexus LX 470
    take a look at this brake bleeder........no need for a buddy.......
    Amazon $20........just keep pump higher than the catch bottle......
    use it also to suck out P/S reservoir too.....then refill/drive/refill........
    3-4 times will clean it out purty good......I think......I've been wrong once.........:crapstorm:
  9. Feb 27, 2018 at 6:09 AM
    mitchbuck
    Cape Cod
    12 Taco 2xCab SR5
    Thanks I will take a look at this kit.
