Crossover locations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jun 11, 2023.
  1. Jun 11, 2023 at 8:13 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    For all you audio gurus out there:
    Curious where you guys put the crossover for your component speaker setups. Thanks.
  2. Jun 11, 2023 at 8:53 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mine are inside the kick panels in driver/passenger footwells
    MalinoisDad and Logans2001[OP] like this.
  3. Jun 11, 2023 at 9:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mine are behind the door panels. For a while I considered whether I would ever want to change the settings from where I set them and decided it was unlikely. My system has now been in there unchanged for 8 or 9 years. YMMV
    Logans2001[OP] likes this.
  4. Jun 12, 2023 at 12:45 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    I put mine behind the door panels. Left it on max settings and haven't looked back since.
  5. Jun 12, 2023 at 12:45 AM
    ATEXANYALL
    ATEXANYALL Member
    2003 Tacoma PreRunner 2.7
    In my kick panels.
  6. Jun 16, 2023 at 3:07 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Kick panels worked out nicely. Thanks dudes
