cruies control not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by sean slovisky, Mar 24, 2014.
  1. Mar 24, 2014 at 7:09 PM
    sean slovisky
    sean slovisky [OP] Member
    texas
    99 tacoma 4x4
    when i first got my truck my cruise control was working but i had to push the the set botton several times now it will not work at all the light comes on but it will not ingage any ideas
  2. Mar 24, 2014 at 7:44 PM
    Madjik_Man
    Colorado Front Range
    Don't know if this will help because of the first part of your sentence, but there is a switch at the top of the clutch pedal that needs to be depressed in order for the cruise control to work.
    Over time the clutch pedal gets a little more play at the top to the point that it no longer pushes that switch in enough to have the cruise control work.
    Try putting your foot under the clutch pedal and pulling it up all the way... while doing that see if you can engage cruise control. If that works then all you have to do is adjust your clutch pedal so that there is less play at the top.
    Atowns40 likes this.
  3. Mar 24, 2014 at 7:47 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    This^^^ should be the reason why, if you don't have a manual I have no clue :confused:
  4. Mar 24, 2014 at 10:37 PM
    sean slovisky
    texas
    99 tacoma 4x4
    thanks i try that just about to roll 300000 so ya im sure its a bit loose
  5. Mar 25, 2014 at 6:26 PM
    sean slovisky
    texas
    99 tacoma 4x4
    i tyred pulling up on the cluch that did not do it any other ideas
  6. Jan 8, 2016 at 11:28 AM
    Offalot
    Offalot Member
    Is the replacement of a 2001 taco an easy replacement, or will I need professional help?
  7. Jan 8, 2016 at 11:32 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is your battery/alternator going out?
    I had a bad battery terminal once and cruise wouldn't function until I replaced it.
  8. Jan 8, 2016 at 11:32 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    You will need professional help to replace a 2001 Taco. Replacement is very hard to do. I honestly don't know how people do it.
  9. Jan 8, 2016 at 12:29 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  10. Jan 8, 2016 at 1:14 PM
    Offalot
    Offalot Member
    Thanks for the info. I might just go without it......
  11. Jan 29, 2016 at 7:08 PM
    Offalot
    Offalot Member
    Update: The springs on the clutch pedal control (manual) broke through the housing, causing a failure of the cruise control (sensor). Replaced the bracket and cruise works just fine. Almost broke through both sides of the bracket. Lucky, I guess. but 220,000 miles later I guess it's somewhat expected....
  12. Feb 6, 2016 at 8:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Ive been having issues with my Cruise control...I hadnt got around to looking into it much, found the clutch pedal switch gap excessive fixed that and it worked for a bit, then cruise quit working again! So yesterday I check under the hood and the cable was loose, put it back in its bracket and tightened up the nuts and it works again!
  13. Feb 6, 2016 at 8:50 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    If it isn't that, check the fuses. I believe there's a 20 amp fuse for the CC if memory serves me correct.
  14. Feb 6, 2016 at 8:52 AM
    wilcam47
    Will
    Bourbon state
    I havent found the fuse location for mine as of yet..
