Cruise Control Addition
Discussion in '1st Gen. Tacomas (1995-2004)' started by Racerboy221, Mar 20, 2011.
  1. Mar 20, 2011 at 1:23 PM
    Racerboy221
    Racerboy221 [OP] Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    My Taco is a base model....no real frills. I was wondering what it would take to add Cruise to it. I am not really sure of all of the components needed and was wondering if there was someone with that knowledge.
    http://cgi.ebay.com/ebaymotors/96-04-Toyota-Tacoma-Cruise-Control-Switch-lever-adjust-/370490288368?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998|Model%3ATacoma|Make%3AToyota&hash=item5642f128f0
    I found this unit for sale on eBay but was not sure if there were additional parts needed or will it wire straight up? The truck has a bunch of unused wire harnesses under the dash....I have added a digital clock, ordered the power windows since the wiring was in the door already.
    I hope the cruise is the same. Anyone know?
  2. Mar 20, 2011 at 5:59 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    i would actually really like to know if this would work cause cruise control would be nice to have on my truck.
  3. Mar 22, 2011 at 9:04 AM
    Sign Guy
    Sign Guy Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    I know there is more to it than just the lever. You need the actuator to pull the throttle. I installed an audiovox CC on my Ranger and there were a few more pieced than just the part on the column. I am heading over to Missoula for the weekend, maybe I'll try to find this junkyard and ask the guy if I have time. Strange that unit has that metal bracket on it, I wonder where that goes????
  4. Mar 22, 2011 at 9:13 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Gen 1 have throttle cable I'm assuming so yes, vacum & control cable pieces under the hood. Clutch pedal has cutoff relay if not automatic trans. Might need brake pedal cutoff relay. Not sure what else. Mine is gen 2 with drive by wire so all I needed was clutch cutoff relay, stalk, steering wheel wire and steering wheel cover piece where stalk comes out.
  5. Mar 22, 2011 at 11:41 AM
    Alejo
    Alejo Member
    Alejo
    Fl
    98 prerunner, 2.7, acces cab
    That par is for a OEM cruise control, you more parts to add cruise control to you truck
