Cruise Control and Turn Signal problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ruf, Oct 9, 2019.
  1. Oct 9, 2019 at 9:54 AM
    Ruf
    Ruf [OP] New Member
    I have a 2008 4cyl 2X4 with 160k miles. I just got it and don’t know much about it, but according to Toyota’s website, the recalls are up to date. There aren’t any codes thrown. The cruise control went out (no light on dash and doesn’t engage) a few weeks back, as well as the power outlets under the radio. I replaced the fuse for the power outlets and they work now, but CC still doesn’t. I took off the CC switch to see if the internal mechanical switch broke. That wasn’t the problem, so I put everything back. Now the turn signals do not work. Also, the tire pressure light won’t reset and sometimes blinks for no reason. There aren’t any other dash lights on other than the tire pressure light.
    I don’t know when the coil spring recall was done, so I’m not sure if it has problems again. Is there a way to troubleshoot the problem without blindly replacing parts and hoping that’s it? I’m a novice when it comes to car repair. Any help is appreciated. Thanks.
  2. Oct 9, 2019 at 9:56 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    youtube has a good video about how to replace spiral cable
  3. Oct 9, 2019 at 2:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Spiral Cable. Common issue.
