Cruise control causes surging when engaged
Discussion in '1st Gen. Tacomas (1995-2004)' started by ldmckiny, Jan 26, 2022.
  1. Jan 26, 2022 at 9:15 AM
    ldmckiny
    ldmckiny [OP] Member
    Larry
    99 Tacoma V6
    I’m looking for help on why my cruise control causes surging of speed when engaged. The acceleration and deceleration is quick and feels as if I were accelerating and decelerating rapidly to maintain a permanent speed. Although it does maintain the set speed this surging is actually profound enough that it causes my body to shift forward and back. Pretty sure this is not good for engine or transmission function, and certainly mot my comfort when using.
    Any insight as to possible cause is appreciated!
    straightawaykid likes this.
  2. Jan 26, 2022 at 4:10 PM
    straightawaykid
    straightawaykid Member
    Dave
    Toluca Lake, CA
    2002 Black Taco Xtra Cab SR-5 V6 4WD TRD with Leer shell
    When I asked (in 2002), the dealer said it's common, and there is no way for him to adjust it. To keep it from shifting up & down, they said to turn off overdrive, or select a lower gear. That way it won't keep hunting gears up & down. It does depend upon how steep the hill is. Hope I got the correct symptoms you have.
  3. Jan 26, 2022 at 4:41 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Out of curiosity have you checked for any vacuum leaks?
  4. Jan 26, 2022 at 4:49 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Check the battery clamps. Loss of continuity, will mess with the computer causing the CC to lose communication.
  5. Jan 26, 2022 at 5:14 PM
    Glamisman
    Glamisman Well-Known Member
    if the engine can not develop enough torque/HP to maintain the desired speed then the trans will down shift, this is normal. Check for excessive slack in the cruise control cable at the throttle bell crank.
  6. Jan 28, 2022 at 7:33 AM
    ldmckiny
    Larry
    99 Tacoma V6
    Thanks for the responses, but just to clarify, the transmission is not shifting down and the action is the same with overdrive on or off. What’s happening is the same effect as if I were accelerating then decelerating constantly with a resulting jerk in speed in both instances. Think of trying to stay within a few inches of a car in front of you going 60 mph and you’re trying to stay within a few inches of its back bumper only using the accelerator and not the brake.
    Also, I failed to mention that this is an after market add on which was done by the previous owner. I’ve had the truck for over 6 years.
    If anyone has a schematic of a typical aftermarket system that might help. I can’t seem to find one on the web. thanks again for any help or ideas.
  7. Jan 28, 2022 at 7:35 AM
    ldmckiny
    Larry
    99 Tacoma V6
    Also, it’s a ‘99 model PreRunner….
  8. Jan 28, 2022 at 7:38 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    First thing I'd do is remove the aftermarket CC.
    It shouldn't surge. Changing engine speeds and trans shifting for hills is normal. Surging on level roads is not normal.
    Then if you must have CC, suggest to purchase another aftermarket to install or have the dealer install an OEM system.
  9. Jan 28, 2022 at 8:14 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Maybe check the slack in the cruise control cable that goes to the throttle body. There should be just a teeny tiny bit of slack.
  10. Jan 28, 2022 at 10:05 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Outside of checking the tension of the cables, I don't think many here are going to be able to help troubleshoot an aftermarket CC.
    Your best bet might be to locate the unit itself and find a manufacturer or model and see if you can get in touch with that company.
