Cruise control doesn't work sometimes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacomatrd, May 15, 2012.
  1. May 15, 2012 at 9:32 PM
    04tacomatrd
    04tacomatrd [OP] Member
    Louisiana
    04 SR5 TRD Off Road 4WD
    Bed cap
    sometimes my cruise control works fine and sometimes it doesn't...anybody know why?
  2. May 15, 2012 at 9:32 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    How fast are you going when it doesn't work?
  3. May 15, 2012 at 9:36 PM
    04tacomatrd
    Louisiana
    Bed cap
    about 70..but i've tried it at 70-75 many times..always worked.
  4. May 16, 2012 at 2:58 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Does ur horn still work?
    Neither of mine work....damn "clock spring"
  5. May 16, 2012 at 6:55 AM
    Madjik_Man
    Colorado Front Range
    Can you turn on cruise control, just not set it? If so...
    Make sure your clutch pedal is coming back to the full top position.
    It may not be making contact with the cruise control switch. This is exactly what was happening with mine.
    If it happens while youre driving, just put your foot behind the clutch pedal and push it all the way up. Then try it again.
    Post #6 was incredibly helpful (as were a couple more of his posts later in the thread): http://www.tacomaworld.com/forum/1st-gen-tacomas/213113-cruise-control-problem.html
    For me it turned out that the switch was a little gunked up, but the real issue is my clutch pedal doesn't always come all the way up every time.
  6. May 16, 2012 at 7:04 AM
    Black Hills Tony
    Black Hills Tony Active Member
    Joseph, Or
    03 TRD 4WD
    Check your shift nob adjustment if you have an automatic transmission. I have a little bit of "play" in my transmission gear selctor. I've had situations when I put it in "drive " but it was just slightly pushed forward toward "neutral". It'll drive fine, but cruise control won't work. I've learned that I just need to jig the shift nob back to that it is fully set in the "drive" position. Then my cruise control works. Maybe you have same issue.
  7. May 16, 2012 at 7:17 AM
    Madjik_Man
    If you scroll over his truck description (dashed blue lined box under his name) it says he has a manual :notsure:
  8. May 17, 2012 at 2:51 PM
    tacocowboy300
    tacocowboy300 New Member
    Josh
    colorado
    2013 TRD OR DCSB
    Bilstein 6112/5160 , Wheelers 3 leaf AAL, 265/75r16 Toyos, All Pro Off Road front bumper, Coastal High Clearance rear, Baja Designs lights
    Check the upper clutch switch when your driving by pulling up on the clutch pedal with your foot, hold it there, and then try setting the cruise. My truck was having the same issue and I ended up replacing that switch/sensor and all is good now. If you look under the dash and look at the clutch pedal arm you will see what Im talking about, it will be engaging that sensor when the pedal is up.
  9. May 17, 2012 at 4:45 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I started getting aggravated with mine because every now and then the cruise control wouldn't work and then I realized it was only when I used the clutch start cancel to start my truck.
  10. May 17, 2012 at 4:52 PM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    This is similiar to what happened in my wife's 06 corolla. Check your clutch like others said, put your foot under the clutch pedal, lift it up and try to set it. For us the switch went bad, had to buy a new one on ebay.
  11. May 17, 2012 at 6:01 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Make sure it's in drive. Move the lever forward and back to make sure. I've had this happen to me every once in awhile.
  12. May 18, 2012 at 6:37 AM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    :D Thnaks...
  13. May 18, 2012 at 7:01 AM
    04tacomatrd
    Louisiana
    Bed cap
  14. May 18, 2012 at 8:04 AM
    Madjik_Man
    Did you diagnose it?
  15. May 18, 2012 at 8:33 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Whats the minimum speed the cruise control can be set at? I was in a 15mph zone and well.... im not very good at cruising at 15mph for more that a couple minutes... so i tried to set the cruise control but it wouldn't work. kind of annoying. I can get it to cruise at 35 i think.
  16. May 21, 2012 at 11:16 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I have tried pulling up on the clutch pedal and still nothing happens for me, the cruise light cuts on but won't set. I think my clock spring is bad though rather than it bein that switch... Damn rack and pinion install
  17. May 21, 2012 at 11:22 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    I believe it's 25MPH
  18. May 22, 2012 at 5:44 AM
    Madjik_Man
    Are you getting under the dash and seeing if the clutch pedal is making contact with the switch?
  19. Oct 19, 2016 at 6:51 PM
    WhiteTacomaTRD
    WhiteTacomaTRD Member
    Ricky
    2006 Tacoma Double Cab 4WD TRD 4.0L
    I've got an '06 that's an automatic and I just put a brand new cruise control switch on mine and it's still acting weird. Sometimes the "cruise" light comes on and it works fine, sometimes I'm pressing the "on-off" button and I can't get it to do anything. Please help me out.
  20. Jul 15, 2017 at 6:22 PM
    GrimeyGoose
    GrimeyGoose Member
    Bandera, TX
    PreRunner 6" Lift LT315/70R17 ShrockworksBmpr
    PreRunner 6" Lift LT315/70R17's Shrockworks Bumper with 9000# Warn inside
    Did ya ever figure this out?
