Cruise Control erratic '99 Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by us271934, May 30, 2008.
  1. May 30, 2008 at 7:41 PM
    us271934
    us271934 [OP] New Member
    Austin, Texas
    99 Prerunner V6 Auto
    The cruise will continuously accelerate then decelerate after you set it. The rate of change isn't large but it is just like someone that pumps the gas while driving because they can't seem to hold a steady speed - yes, my wife once did this :)
    The full range of speed is probably around 5 mph.
    I hate to have the dealer charge me $100 to say "this vacuum hose was leaking" plus have my taco at the shop all day.
    Anyone have a similar issue and a solution?
  2. May 30, 2008 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are all your vacuume lines free of cracks? You may want to check the linkage going to the throttle body from the cruise control.
  3. Jun 5, 2008 at 6:27 PM
    TheOriginalTXTACO
    TheOriginalTXTACO Active Member
    San Antonio, TX
    Unfortunately No More
    3" lift, Extreme LineX, Extang Toolbox Tonnoe, UWS Box, MB Wheels, BFG AT's.
    My 02 has always worked like crap, same for my 96. I just don't use it unles I'm hauling ass at 80+, then it works fine.
  4. Jun 5, 2008 at 9:27 PM
    747 function > form
    1st Gen.
    Same issue here...though inconsistent. Is it an aftermarket control?
  5. Jun 6, 2008 at 6:05 AM
    TheOriginalTXTACO
    San Antonio, TX
    Both stock, when it hits a slight hill it surges the gas and up's the rpm, then it abruptely backs off again when back on the flat. I wonder since I lifted both trucks and put larger tires on if this didn't help cause it to be less effective.
  6. Jun 6, 2008 at 6:11 AM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    That actually sounds normal? Mine does that on hills because it's trying to maintain the speed its set at and the hill presents a problem with maintaining that--it'll brake going down hills too in order to stay at the preset speed. Although if its over-doing the rpms that could be a problem. I find cruise control a bit freaky in general. But then I'm a control freak... :)
  7. Jun 6, 2008 at 9:49 AM
    TheOriginalTXTACO
    San Antonio, TX
    I just don't use it anymore, after riding my wife's acura which handles perfectly with the cruise control I can't stand the flucuation with mine.
