Cruise control flashing/not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew-z, Nov 6, 2011.
  1. Nov 6, 2011 at 6:11 PM
    drew-z
    drew-z [OP] dude
    White 05 prerunner SR5 Double Cab
    AFE Brute Force CAI, pioneer touchscreen, pioneer flat series 12" sub/ custom box, window tint, HIDs, LEDs overhead, timbren suspension, BHLM, 2" leveling kit
    My cruise control light is flashing and it does not work. How do I fix it?
  2. Nov 7, 2011 at 7:30 PM
    drew-z
    drew-z [OP] dude
    can anybody help me out here?
  3. Nov 7, 2011 at 7:31 PM
    CanisLupus
    CanisLupus Well-Known Member
    Ashburn | VA
    '11 Toyota Tacoma - '17 Yamaha FZ-09
    I don't really have any clue but have you looked in your owner's manual for anything about this?
    -- Matt --
  4. Nov 7, 2011 at 7:31 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    does cc engage?
  5. Nov 7, 2011 at 8:08 PM
    drew-z
    drew-z [OP] dude
    Cc does NOT engage. It just flashes as soon as I turn it on
  6. Nov 7, 2011 at 8:09 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    does your horn still honk? have you had it read by a scanner
  7. Nov 7, 2011 at 8:13 PM
    drew-z
    drew-z [OP] dude
    Yes horn honks and no I have not had it read. my truck is going into the shop wednesday because I have problems in the rear end. Ill have them check out the cc too.
  8. Nov 7, 2011 at 8:16 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    have them try to read it with a scanner, it could be anything from a loose wire to just the bulb going out
  9. Nov 7, 2011 at 8:18 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    Does your speedometer still read correctly?
    Do the tailights light up when the brake pedal is depressed?
    Do the tailights turn off when the brake pedal is at rest?
    One of these should be the problem. If not then you need to get access to a scanner and give us a Diagnostic Code so we can help you.
  10. Nov 7, 2011 at 8:24 PM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    '11 DCSB MGM
    Plasti Derp'd Emblems rear bumper and grille. Debadge tail gate, Powder coat OR rims.
    So you engage it but it but doesn't work?
    Mine does the same thing, but later i figured out that mine doesn't come with cruise control. Which I think is total bs.
    Here's a link to the DIY for CC
    http://www.toyotanation.com/forum/t171992.html
  11. Nov 8, 2011 at 7:17 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    When I first got my truck and tried to use the cruise for the first time or two, the light would go on but I could not get it to engage. Turned out it was the sequence of moves I was doing with the switch arm which did not allow it to engage. All I did was go back to the manual and re read the cruise control procedure and its worked ever since! :D;)
  12. Nov 8, 2011 at 7:32 AM
    UH60Hwkdrvr
    UH60Hwkdrvr Well-Known Member
    Enterprise, AL
    '18 Toyota Highlander Limited Pre-dawn Gray Mica
    I am betting you have a bad brake light switch. Check to see if your brake lights work when the pedal is depressed.
    m.a.c.
  13. Nov 14, 2015 at 7:23 AM
    wannabemtnbiker
    wannabemtnbiker Member
    Derrick
    2008 White Tacoma Prerunner
    My 2008 Prerunner's CC is doing the same thing. Everthing else mentioned above is operating correctly. Other than my radio does periodically come on by itself and change stations when on.
  14. Nov 17, 2015 at 7:10 PM
    wannabemtnbiker
    Derrick
    Your right!!
    I put my left foot under my brake pedal and lifted it and my CC would engage and immediately disengage when I realesed the brake.ASAP I'm going to check to see if I can adjust tension on the switch plunger
