Cruise Control - High RPMs on hills
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AutoTaco, Jan 2, 2021.
  1. Jan 3, 2021 at 4:07 AM
    #41
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    These engines are designed to get max HP and torque around 4600 RPM. Running 3000 RPM won't hurt a thing. Don't use cruise control in hilly terrain.
    And just because it is an automatic doesn't mean you don't have control over which gear is best. If you wait for the truck to downshift it only does it AFTER the engine starts to struggle. A good driver reads the terrain and anticipates where you'll need to downshift and will do it manually BEFORE the engine starts to struggle.
    cryptolyme and jsinnard like this.
  2. Jan 3, 2021 at 5:02 AM
    #42
    AutoTaco
    AutoTaco [OP] Well-Known Member
    Jay
    Pittsburgh, PA
    2021 Lunar Rock TRD Pro
    Calliraised Sliders, Diamondback HD, 265/75 Wildpeaks
    Haha I live in an area called “north hills”. I work on a mountain. There is no way to avoid hilly terrain here.
    I’ll just have to deal with it by the sounds of it.
    If only the tundra or 4Runner Trd pro had the same features as the Tacoma. I would have freaking bought one instead. I need blind spot monitoring and I also like 360 camera, it’s great for tight spaces.
  3. Jan 3, 2021 at 5:19 AM
    #43
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Seems like the problem is improving itself. Yesterday it was “skyrocketing” over 5k RPM. Today it’s down to 3k. Wait til tomorrow, it will probably only “skyrocket” to 2k
    eurowner and Chew like this.
  4. Jan 3, 2021 at 5:26 AM
    #44
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    par for the course.. in my opinion it seems the trucks are under geared and no low end tq.. probably for the epa. my 2017 just seemed so difficult to keep at a steady speed (over like 55 mph) on the highway, hit the slightest incline and the truck either slows down too much or down shifts so far that the rpm has to go over 4000 rpm.. cruise control is even worse, it seems to shift down way too late which is why it has to spin at 4+ thousand RPM. very annoying truck to drive on the highway in my opinion and all that is unloaded. once you put a 5000 pound trailer on the back it really gets annoying..... not very refined. can't believe its still the same way on the 21's.
  5. Jan 3, 2021 at 6:28 AM
    #45
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    I have a 2020 and mine is the same. I hardly use cruise any more.
  6. Jan 3, 2021 at 7:41 AM
    #46
    AutoTaco
    Jay
    Pittsburgh, PA
    Yea. Makes me sad I would have to avoid cruise on a 47k vehicle.
    CSVT and bensonxj like this.
  7. Jan 3, 2021 at 7:49 AM
    #47
    khaki2020offroad
    khaki2020offroad In the woods, an ambulance, Or on the couch.
    Dennis
    Great Lakes
    2020 QS DCLB OffRoad
    Butt indentations
    My truck does the same thing. I pulled a trailer and it was even worse (obviously)
    I think it would be more appropriate to know just how much fuel is being used at these higher RPMs. Just because the RPMS are higher does not mean you are using more fuel. Have you ever driven a manual transmission and kept it in gear or down shifted for that matter and were not on the throttle?
    I wish we had a real “eco” button that came from Toyota. The bar chart is nice/ but it’s pretty dumbed down. A real wideband read out and live fuel usage read out would be the telltale.
  8. Jan 3, 2021 at 7:50 AM
    #48
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Your truck's transmission is now configurable for different driving situations according to the owners manual.
    Most automatic transmissions have a single OD gear, your truck has two so its characteristics will be different from others you may be used to.
    davidstacoma, Chew and RedWings44 like this.
  9. Jan 3, 2021 at 7:52 AM
    #49
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    They'd also not have the reputation for reliability like they do.
    Chew and khaki2020offroad like this.
  10. Jan 3, 2021 at 7:53 AM
    #50
    RedWings44
    Michigan
    I don't know anyone who has said redlining is normal. 6K is redline in these trucks. We're talking about 3500, which is the power band in these trucks.
  11. Jan 3, 2021 at 7:54 AM
    #51
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    If you dont want your truck to shift automatically then what other option is there? Is the A/T truck supposed to know what gear you want it to be in?
    Chew, khaki2020offroad and RedWings44 like this.
  12. Jan 3, 2021 at 8:04 AM
    #52
    garander
    garander Well-Known Member
    2019 trd sport dcsb mt
    I know you’re not having any problems with your transmission .
    But dude your shift knob as got to go .
  13. Jan 3, 2021 at 8:10 AM
    #53
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    I used my cruise control on the highway yesterday and it would downshift 1 gear (6 to 5) going up an incline. The RPMs would rise to around 2.5k IIRC going up the incline. It worked exactly like I expected. And for the record I have stock suspension and tires.
    Here is the big difference though. I was only going 68mph and the inclines are gradual. You said you were driving 70-75 and work on a mountain. I could see where at your speeds and the steeper mountain roads it is going to downshift to a lower gear and rev higher.
    I think widely varying opinions of how these trucks drive is due to the way they are being used. I am very happy with mine but It is relatively flat around here and the speed limits are mostly 65 on the highways. If I lived in a mountainous region and was driving on roads with a higher speed limit I might not like my truck nearly as much.
    davidstacoma likes this.
  14. Jan 3, 2021 at 8:16 AM
    #54
    Tripod1404
    Tripod1404 Annihilator tripod
    Nah, lets act like toyota intentionally designed the gear point bad to damage the engine, or maybe it is the EPA, I dont know, anyone but the driver must be the problem for sure.
  15. Jan 3, 2021 at 8:55 AM
    #55
    AutoTaco
    Jay
    Pittsburgh, PA
    Thats a good tip. Maybe I'll try that too. I don't mind bumping it down a gear to prevent it from over downshifting.
  16. Jan 3, 2021 at 8:57 AM
    #56
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Rtfm
    Cruise control 101: don't use it on massive hills.
    :smack:
    davidstacoma and Chew like this.
  17. Jan 3, 2021 at 9:01 AM
    #57
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah that is just an internet photo, l replaced that shift knob as soon as l got the truck home from the dealership.
    CygnusX191 likes this.
  18. Jan 3, 2021 at 9:01 AM
    #58
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    To many times to count.
    I drove Toyotas for 15 years, and the 3rd gen just wasn't for me, at all. No torque in the low rev range, right where a truck needs it. Plus, I just needed a bigger truck, have had 3 2nd gen Tundras, don't need a big ass half ton. All GM forums don't compare to this one for entertainment.
  19. Jan 3, 2021 at 9:02 AM
    #59
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Got my 2017 vftune to 2.0 is drives great. I haven’t tried the MW tune because I loved how the 2.0 vftune drives. Someone near you may do it for you for a small fee.
  20. Jan 3, 2021 at 9:05 AM
    #60
    eurowner
    eurowner Duke Sky
    Scoty
    100% true. Ascending to Flagstaff on I17 north.
