Cruise Control isn't working !!!!Help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gr8WhiteTaco, Nov 20, 2009.
  1. Nov 20, 2009 at 12:13 PM
    Gr8WhiteTaco
    Gr8WhiteTaco [OP] bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    My cruise control isn't working on my truck. The CC light comes on when I turn it on, but it doesn't hold the speed or anything. I checked the fuse blocks to see if its was a blown fuse but couldn't find a slot for CC. Any help at all would be great.
  2. Nov 20, 2009 at 12:19 PM
    Resmondo
    Resmondo Well-Known Member
    Cody
    Perdido Key, Fl
    98 SR5 4X4 purple, lifted, and sexy
    Arb Bull Bar, Trailmaster 6" lift with 16"weld rims wrapped in 36 tls radials, Salt life sticker, spacer lift front, 9-10" total front
    You should have a plastic peice that attaches to your throttle assembly on the motor. And the box for cruise control should be on the passenger side fender well with a cable running to your throttle. I have a 2.7 ltr and thats how it is set up. Not sure on yours though. But had the same problem and when i looked the pin had come out of the plastic peice and was dangling down. Re-attached it and it worked fine. Hope this helps.
  3. Nov 20, 2009 at 12:20 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Ok gonna go check that out. I've got the 3.4 so it might be different but its worth a shot.
  4. Nov 20, 2009 at 12:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check the brake switch adjustment.
  5. Nov 20, 2009 at 12:30 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Ok just looked at the cruise control box, the cable is attached, wires are plugged so I don't what it would be.
    wheres the brake adj switch jbob?
  6. Nov 20, 2009 at 12:37 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    your brake switch on your brake pedal.is this automatic or manual truck?
  7. Nov 20, 2009 at 12:43 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    its an auto. all the bulbs and turn signals work.
  8. Nov 20, 2009 at 12:48 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    get down where you can see the brake pedal and the brake switch.notice when you push the pedal how the switch works ,make sure the switch is contacting the brake pedal fully when released.
  9. Nov 20, 2009 at 12:55 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    alrighty just checked the brake switch. it touching it but if i push the it doesn't contact it anymore. Which I'm guessing that is what its supposed to do
  10. Nov 20, 2009 at 12:55 PM
    98tacoma27
    Ben
    Not Beech Creek
  11. Nov 20, 2009 at 12:57 PM
    98tacoma27
    Ben
    Not Beech Creek
  12. Nov 20, 2009 at 12:59 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    yes ,when the pedal is released you want the switch to be contacting completely,if there is any slack adjust it down.
  13. Nov 20, 2009 at 1:03 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Thank you so much Ben!! I been looking for that stuff!
    Ok so jbob i think i can mark that off the list for possible problems.
  14. Nov 20, 2009 at 1:05 PM
    98tacoma27
    Ben
    Not Beech Creek
  15. Dec 4, 2009 at 10:04 AM
    K-K-K-Kommando
    K-K-K-Kommando Active Member
    Is your caps lock on?
  16. Dec 4, 2009 at 10:06 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
  17. Mar 29, 2012 at 6:07 PM
    pou4518
    pou4518 Member
    Natchez, Ms
    2000 Tacoma, extended cab, 4wd, 177K+
    None Yet!!
    Did you ever figure out your issue mine is doing something very similar..
