Cruise control issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by kiett, Mar 25, 2015.
  1. Mar 25, 2015 at 11:51 AM
    kiett
    kiett [OP] Well-Known Member
    South Carolina
    15 TRD PRO & 94 Hardtop Turbo MR2
    I've tried searching and reading threads but I cannot come up with a conclusion.
    I have a 2002 v6 auto taco and I cannot get the cruise control problem fixed.
    When I press the button to turn on cruise control the light comes on and goes off as soon as I release the button. When the light goes off I hear an audible click from the center of the car somewhere.
    I do know how to use the cruise control so that's not the issue.
    I tried removing the harness in the engine bay and re plugging it back in but that didn't work.
    I do have an abs light on, but I wasn't sure if that effected it. ( cannot communicate with abs unit)
    I checked the brake light switch and it looks fine. I have all my brake lights when depressing the pedal.
    any ideas?
    thanks!
  2. Mar 27, 2015 at 2:10 PM
    kiett
    South Carolina
    Bump is the cc module a common thing to go out?
  3. Mar 27, 2015 at 2:56 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Crouse module is not common to fail. You said your air bag is on, is there a chance your spiral cable is bad? Are horn and turn signal s fine?
  4. Mar 27, 2015 at 6:15 PM
    cep89
    cep89 Well-Known Member
    Michigan
    2017 MGM TRD OR DCSB
    I would get the ABS system scanned to find out what is the code for. It may be something that prevents cruise control from working. Some auto parts stores have scan tools and will scan it for free. ABS is the anti lock brake system. Even though your brake lights work the brake light switch could be a fail for ABS.
  5. Mar 27, 2015 at 6:18 PM
    koditten
    Kirk
    Central Michigan
    Cruise control is not tied into the SRS on a First Gen. '02 don't have anti lock breaking if I'm not mistaken. I think '04 was the first year.
    Howdy CEP, see your from the state.
  6. Mar 27, 2015 at 6:25 PM
    cep89
    Michigan
    Mich. is a cool state, moved here from the Chicago area about 10 years ago. Would never move back.
    My 1999 has ABS. It was an option for many years and then became standard equipment.
  7. Mar 27, 2015 at 6:32 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Check your fuses too, there is one for CC and it might be blown. But typically, the light just wouldn't come on at all if that were the case. Still wouldn't hurt to look and see.
  8. Mar 27, 2015 at 6:39 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Possibly the brake/clutch switches?
  9. Mar 27, 2015 at 6:41 PM
    koditten
    Kirk
    Central Michigan
    Option, that's right. Standard in '04. Thanks.
    Does the OP have anti lock brakes? If so, I know on the Gen2's a bad wheel speed sensor will keep the cruise from working. Not sure about 1st gens.
  10. Mar 27, 2015 at 8:59 PM
    kiett
    South Carolina
    Abs light is on because computer issue. Been trying to find another one but no luck. Got it diagnose. Diagnostic computer was unable to communicate to the unit.
    I checked the brake switch and the plunger is still there and all the tail lights light up when pressed and shuts off when not.
    Thanks for all your replies. I hope I could figure this out
  11. Mar 28, 2015 at 5:47 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    If your having Ecm/computer issues, that needs to be found and fixed first.
  12. Mar 28, 2015 at 6:01 PM
    cep89
    Michigan
    I agree.
  13. Mar 28, 2015 at 8:43 PM
    kiett
    South Carolina
    Only thing I have wrong now is the diag computer not being able to connect with the abs computer.
    I wish I could find the cc computer to see if that's the issue. Looks like PO had it in some mud as there is lightly dried dirt in that side of the truck.
