Cruise control module compatability across models
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zachary_D, Jan 28, 2016.
  1. Jan 28, 2016 at 6:29 PM
    Zachary_D
    Zachary_D [OP] New Member
    Zach
    04 Extra Cab 2.4 M/T SR5
    Hello all, I've been lurking around for a while and have already searched all over the web for this.
    I have an 04 2.4 M/T SR5. I want to add factory cruise but cannot find the cruise module under the right kick panel. The part number I need is 88240-04040. Very elusive.
    However, I have found a few for the 2.7 with a M/T. # 04020 I think.
    My question is: Will this module or another work?
    Thanks
    Zach
  2. Jan 29, 2016 at 2:01 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I would also be interested in finding this out! There's a cruise module under the right kick panel?
  3. Jan 29, 2016 at 6:44 AM
    Zachary_D
    Zach
    That's where plug in is. The actuator is over the right fender for the 4cyl
    I just found a site called Toyodiy.com that allows you to cross reference part numbers. It says that the module (88240-35230) from the 96-2000 2rz is compatible. I hope it is correct because I just bought one. Wasn't too expensive so not much damage done if it don't. I'll let you know what I learn.
    The 3rz modules seem to be much more plentiful though.
