Cruise Control Not Engaging
Discussion in '1st Gen. Tacomas (1995-2004)' started by FWAdam, Sep 8, 2016.
  1. Sep 24, 2016 at 8:13 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    maybe the brake disconnect switch is out of adjustment. Mine also wasnt working and I had two problems one the clutch pedal switch wasnt engaging and the cable that controls the speed was loose and fell off the Throttle body. I reinstalled the cable and tightened down the adjustment nut and adjusted my clutch pedal disconnect switch and it works. I know OP is auto but maybe its something loose?
  2. Sep 24, 2016 at 9:53 AM
    FWAdam
    FWAdam [OP] Well-Known Member
    Indiana
    2001 Regular Cab Prerunner
    DIY Frame replacement New rear leaf springs (General Spring, stock height) Wheeler's greasable shackles Bilstein 5100 / 5125 Roll-on bedliner Poly bushings all around Leer topper Michelin Defender LTX M/S tires New drum brakes, rotors and pads, and Nickel-Copper brake lines Window tint Wheels painted black Interstate battery New spark plugs Chrome bumpers painted Bucket seats and console (soon) Emblems plasti-dipped (soon) 4x4 conversion (2017)
    I checked the cables the other day. They are connected and don't appear to be loose.
  3. Sep 24, 2016 at 10:22 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You can rule out the brake switch, by removing the connector, shorting the 3 and 4 terminals (on the connector, not the switch).
    If the CC works, then you have a bad brake switch. If not, then look elsewhere.
    These switches are cheaply available at any pick-n-pull, for maybe $5. I got mine from a Camry, since most Toyotas of the same year use the same part.
  4. Sep 24, 2016 at 11:40 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I'd suspect in order...
    ...the brake pedal (cruise cancellation switch)
    ...the cruise control lever /or connections
    ...the steering's spiral cable - wiring connections
    Since the CC lever's display light on the dash functions...
    (thought I read so... but may have become confused)
    I might believe that the spiral cable is not
    sending signal/power to the CC unit itself.
    I would think a fault code could be read
    even if that fault does not display an cel.
    Electrical issues are not always easy to self diagnose.
    And can become an expensive process
    if needing to replace every suspect e component that could be of blame,
    in order to find the single fault or make correction.
    I personally would pay for a dealership diagnosis
    and then likely do my own repair(s).
    good luck with yer troubles.
  5. Sep 26, 2016 at 5:36 AM
    FWAdam
    Indiana
    Thanks for the replies, everyone. I've got to tackle a blown axle seal this week and then will get back to the cruise issue. I appreciate all the suggestions. I will be taking a closer look at the brake switch to rule that out.
    I think the CC unit is getting power, as I hear it click when I turn the power on at the stalk, and click again a few seconds after turning off power. Which makes me wonder again if the issue isn't farther down the line. But the brake switch is always a good place to absolutely rule out.
  6. Jan 1, 2017 at 2:30 AM
    FWAdam
    Indiana
    Just to wrap it up: the culprit was the cruise control actuator in the engine bay. Got one used from eBay, swapped it in, and now I am cruising with no problem!
    syswalla, Madjik_Man and chaosrob like this.
  7. Jan 1, 2017 at 8:04 AM
    Madjik_Man
    Colorado Front Range
    Thank you for checking back in and updating the thread.
    It helps a ton with future troubleshooting.
  8. Jan 1, 2017 at 8:17 AM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    I though this, too, on my wife's Honda. I realize this isn't a Toyota but thought I'd mention this anyway.
    Brake lights worked fine, but for years we kept having issues with the cruise working, then not working, then working again. Eventually the brake lights stopped working. (She got to visit with the chief of police over that...lol). I first cleaned the switch, then ordered a new one. Since replacing it the cruise has worked flawlessly.
    That may not be the root of the problem for most here, but don't overlook the possibility.
