Cruise control not working after install of aftermarket tail light assembly?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Jan 28, 2022.
  1. Jan 28, 2022 at 8:45 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Is this something other people experience. I purchased these new after market "tail light assembly" from ebay. (china) for my 2001 Tacoma V6 4X4
    Wondering if the internal wiring in these things could be wrong tho?
    Ever since I installed the new tail light cruise control only works when headlights are off? As soon as you turn on headlights, cruise control STOPS.
    Do you think this tail light assembly is the culprit? Should I return and get OEM?
    In a post located here, its been mentioned in the past
    "Most likely your tail light sockets or bulbs are corroded. Thus the tail lights are trying to ground through the brake light circuit which causes the cruise to see the brakes being applied so it will not engage physical damage to wires."
    Could this be the culprit?
    Everything seems new and not corroded. Could it be something else or are aftermarket tail lights known to do this?
    regards
    -prerunnersd
  2. Jan 28, 2022 at 8:52 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you try the old ones see if CC works?
    unstpible likes this.
  3. Jan 28, 2022 at 9:28 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I wonder if you got a set of taillights designed for the older models. Do you have a picture of the plug for the taillights
    LearningToFly likes this.
  4. Jan 28, 2022 at 9:30 PM
    Montana_Actual
    Montana_Actual ;)
    I had a FORD that did this when the 3rd brake light was out. Did you swap bulbs to LED's? But yes, if it's anything like the same setup it's because the truck is not detecting a bulb (on LED's the voltage is lower). So rather than just put an indicator light in the dash, some genius thought it'd be a great a idea to disable cruise control, lol.
    If you didn't upgrade to LED's retry the bulbs and put some dielectric grease in there with them. Make sure to clean off the connections thoroughly before doing so.
    BlackSportD and LearningToFly like this.
  5. Jan 28, 2022 at 9:40 PM
    prerunnerSD
    USA
    Good idea, however old one is damaged because of an accident.
    Just asking to see if anyone has had this experience before. Seems like these aftermarket tail lights are a big hit online and dozens are sold a day. I would think maybe someone else had this experience.
  6. Jan 28, 2022 at 9:46 PM
    unstpible
    Derek
    Cedar City, Utah
    If the lights are designed for an older model it will cause funny problems like the cruise control to not work correctly.
    There are two different styles of plugs one with 5 pins and one with 6 pins.
  7. Jan 29, 2022 at 7:50 AM
    taylor555
    taylor555 Well-Known Member
    95 Tacoma 4x4 Xtra cab
    stock
    Try disconnecting the ground on the battery. Then reconnect it. This happen to me years ago. And for some reason after I did this my cruise started working again. I'm not sure if the ECU was holding a soft code or what the deal was.
  8. Jan 29, 2022 at 2:52 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Does turning on the headlights also cause the brake lights to energize??
    The cruise control computer sees the brake light circuit energized and disengages.
    It also might be the headlights are grounding back through the brake light circuit causing the same problem
    This can happen in the tail light sockets or the evil converter box .
    Good luck.
  9. Jan 30, 2022 at 9:41 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I had SOMETHING like this happening on my 01 Tacoma and it was a Ford thread when googling that gave me a troubleshooting path.
    ISSUE= Cruise WOULD work but if I turned on my blinker to change lanes (I know, I'm a unicorn) it would shut the CC off.
    It was happening to me cause I had just one LED light in the 3rd/cab brake light (I think there are 3 bulb plugs back there). Fix was to mix in some incandescents. Man, it was driving me up a wall and I thought it was my piggyback.
    OP I think your new lights are LED and its a "feature" not a bug. You can mess around with the LED resistors they sell to see if that fixes the issue.
  10. Jan 31, 2022 at 5:33 AM
    Bob12321
    Bob12321 Well-Known Member
    Robert
    Although them lights look good and new , its a crap shoot. Ive had problems with them working also . I just ordered another set then i had no more problems. Even buying 2 sets is way cheaper than oem
  11. Jan 31, 2022 at 7:43 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    mine did the same thing, it was the bulb itself. Tiny short made the computer think the brake was being applied.
    Bivouac likes this.
  12. Feb 20, 2022 at 7:12 PM
    prerunnerSD
    USA
    Tested the old tail lights and it still does it with that.
    Cruise control turns off when I turn on headlights.
    Also when head lights are off, pressing the brakes makes the dash light and even the clock lights dim while pressing. (see video)
    When I have the headlights on braking does not cause the dimming of the dash or clock lights and everything works normal.
    Recently I had a rear ending fender/bender and it caused some damage to my bumper and broke the lens of my left rear tail light. The bumper absorbed most of the accident. I have replaced it with a TYC brand after market tail light. When plugging in my old OEM tail light it still acts this way so I don't think the after market lights are bad. I don't remember if had this problem before the accident.
    Also prior to the fender bender I had this mod: done to my truck. Done by a buddy of mine. This does require taking apart the steering column. So maybe a wire was crossed or not put in right? Should I check anything else?
    Could the problem be anything in the rear besides the tail light assembly? Since I was hit back there maybe something isn't grounding. However the collision was not severe and original wires seem intact.
  13. Feb 20, 2022 at 7:31 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sounds like a loose ground somewhere. The circuit that cancels your cruise control is finding a ground through your lights, causing it to activate when your lights get energized. I think I’d check under your dash, iirc a bunch of grounds end up by the drivers foot behind the kick panel.
  14. Feb 20, 2022 at 7:43 PM
    prerunnerSD
    USA
    So even though my steering column was taken apart you don't think something could be miswired there? I remember my friend being very methodical though.
  15. Feb 20, 2022 at 7:46 PM
    0xDEADBEEF
    It seems unlikely, all that kind of stuff connects via a plug, and as long as he didn’t leave something unplugged, it would be hard to miss.
    the attached manual might help ya trace it down, I’d start with the brake light switch, or cruise control.
  16. Feb 21, 2022 at 4:36 PM
    prerunnerSD
    USA
    Sorry I’m not an electrician I am not experienced with electrical manuals but at this point do you think this is more of a front end problem? could this be part damage because of the accident or is that unlikely? I was only hit in the rear I tested several tail light assemblies and they all function this way now with the cruise control not working with the headlights on.
