Cruise Control not working although lights up on dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by #sultanofsilver, May 29, 2019.
  1. May 29, 2019 at 10:12 AM
    #sultanofsilver
    #sultanofsilver [OP] Member
    2006 Tacoma
    My cruise doesn't work although the light on the dash does go on. If I replace the brake switch, will this make it work (Just thinking easy quick, first things to rule out) Cant seem to find a fuse for it. Is there a fuse?
    I LOVE using cruise control and this is frustrating.
    wilcam47 likes this.
  2. May 29, 2019 at 10:37 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    very common issue and supposedly related to spiral cable, i believe if you search hard enough you can actually find a recall/free toyota replacement doc on here to get yours taken care of. I have this issue too and sometimes it works, sometimes the light will turn on and it wont work etc.. i've read trailer hitch wiring damage can also cause weird CC issues.
  3. May 29, 2019 at 10:38 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is it auto or manual trans?
  4. May 29, 2019 at 11:52 AM
    #sultanofsilver
    2006 Tacoma
    It is automatic
  5. May 29, 2019 at 3:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here is the diagram for cruise control:
    https://www.customtacos.com/tech.ol...toyewd/06toypdf/ewd/2006/tacoma/h/em01d19.pdf
    These are what causes the system to automatically cancel or not set at all.
    Auto Cancel Function
    If any of the following conditions is encountered, the cruise control is automatically cancelled.
    ∗The stop lamp SW wiring is faulty or short–circuited.
    ∗The vehicle speed signal is faulty.
    ∗The electronically controlled throttle malfunctions.
    ∗The actual vehicle speed becomes –16 km/h slower than the set speed.
    ∗The actual vehicle speed becomes slower than the minimum speed limit. ( minimum speed for cruise is 25 MPH or 40 KPH ).
