Cruise control options for a '97 5-speed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mbtech208, May 11, 2009.
  1. May 11, 2009 at 7:47 AM
    mbtech208
    mbtech208 [OP] Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    My '97 4WD 4-cyl 5-speed doesn't have cruise, but I'd like to add it. Would I be better off adding the OEM cruise, or an aftermarket kit?
  2. May 11, 2009 at 10:13 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If the OEM cruise kits are still available (which I doubt), they'll run more (price-wise) than decent aftermarket kits.
    If you go the DIY route (transplanting cruise from a donor Taco ...) you have to be careful to get *ALL* the necessary components (including controller unit and wire harnesses) for it to be cost-effective. Multiple people have started OEM cruise transplant projects and ended up abandoning them for lack of the proper parts.
    IMHO you're at least as well off (if not better off ...) just going the aftermarket route.
