Cruise control over compensates by 5 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frogging, Jan 1, 2014.
  1. Jan 1, 2014 at 6:05 PM
    Frogging
    Frogging [OP] Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    2013 DCLB 4.0 auto. when i set my cruise control it will over compensate when i go over a bridge. ill have it set at 55mph and when im at the top of certain bridges it will have either down shifted to 4 or unlocked the torque converter and sped up to right around 60mph.
    is this normal for others out in TW?
    if it doesnt down shift, it doesnt speed up otherwise
  2. Jan 1, 2014 at 6:12 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    If you are saying "at the top of certain bridges" I'm going to assume you are travelling on a peaked bridge, not a level one.
    If that is true, then the truck needs to kick it down a gear and accelerate to maintain the setting you originally had while going up a grade.
  3. Jan 1, 2014 at 6:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Normal.
    The cruise can't "see" the rise in the road and it can't react quickly enough to prevent speed overruns and underruns... It simply sees the truck slowing down, and the ECU tells it that the engine is under a high load, indicating climbing a hill or bucking a headwind, so it applies more throttle.
    When the load lightens as the road flattens, it reacts, but it can only react after it sees that the load has lightended and the speed has exceeded the set speed.
    Every cruise on the planet does this. Some are worse than others. It is one reason that cruise should not be used in traffic or in hilly terrain, especially curvy mountain roads.
  4. Jan 1, 2014 at 6:33 PM
    302 I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    This^
    I always felt like cruise on a hill would destroy my transmission. Not sure if it will but don't like it being so jumpy. Cruise on level terrain only IMO.
    3
  5. Jan 1, 2014 at 6:42 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Maybe ever cruise control with an automatic, cruise works perfect with manual transmission every time.
  6. Jan 1, 2014 at 6:43 PM
    Skivvy9r
    Skivvy9r Active Member
    Maryland
    2013 Pyrite Mica TRD Sport
    Normal for the Tacoma. Our cruise control is especially bad. It's slow to engage and slow to respond to terrain changes. I've commented on this in the past and was reminded it's a truck; I shouldn't expect more.
  7. Jan 1, 2014 at 6:45 PM
    Lawrence
    302
    Bedside decal
    Every Camry and jeep I owned did it
  8. Jan 2, 2014 at 11:53 AM
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    thanks for the input. first auto i have owned, so my cruise control on my ford ranger of 10 years was my right foot and it was a manual. guess i was just surpised at the over compensation. i knew it would down shift but didnt expect the acceleration.
    i live in FL so not too many bridges. i started engaging the CC after the larger bridges that it does this on near the beach
  9. Jan 2, 2014 at 11:57 AM
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    it didnt just downshift, i expected that, it went from CC set at 55mph downt to 53mph ish up to 60mph ish then eventually work its way back to 55mph.
    sounds like this is normal though. guess ill just use my right foot
  10. Jan 2, 2014 at 12:25 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup... it dropped to 54/53 and added more throttle, still saw a loss in speed and increase in load to it downshifted, which immediately throws the engine into the middle of the torque curve and results in a quick jump in speed.
    If you're lucky, that's it... it'll settle down back at 55.
    What normally happens to me on longer hills is a repeated series of up/downshifts... at which point I just add enough gas to hold it slightly above the set speed until I hit the top of the hill.
  11. Jan 2, 2014 at 12:31 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Generally when climbing a hill with CC on, I'll turn off O/D to keep the trans from shifting up and down constantly and to maintain a more constant speed
  12. Jan 2, 2014 at 12:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If I think of it before I hit the hill, I'll give it a little extra and get a "running start" on the hill, gradually releasing pressure on the gas as I climb the hill, with the goal of hitting the summit at the set speed.
    Saves gas and nerves that way if I can time it right to avoid any downshifting.
  13. Jan 2, 2014 at 12:48 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    X2
  14. Jan 2, 2014 at 1:08 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My truck does the same thing and I absolutely hate it. While it may be 'normal' for the Tacoma to fluxuate that much while going up a hill, this overcompensation is by far the worst of any vehicle I've owned or driven. I hate that it overcompensates going up hills and, in my opinion, it shouldn't do it, at least not to the extent that it does.
  15. Jan 2, 2014 at 1:12 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    stick shift ftw. My cruise control cant downshift me and hardly ever over compensates.
  16. Jan 2, 2014 at 1:26 PM
    OrangeTexan
    OrangeTexan Well-Known Member
    San Antonio
    2012 4X4 TRD OR
    In my experience, this is somewhat unique to Toyotas:
    My 2004 Tundra did it.
    My 1998 4Runner did it.
    My wife's 2007 and 2009 4Runner do it.
    The 2011 4Runner we test drove did it.
    My wife's 2009 Maxima did NOT do it.
    My IS250 did NOT do it. (but its a Lexus so maybe the algorithm is different?)
    My Hummer H3 does NOT do it.
    NONE of my dad's F150's or F250's do it.
    My cousin's 2500HD did NOT do it.
    Thinking back, I remember some vehicles that I drove while growing up that did it, but things should have improved by now, and in other newer vehicles I have driven the cruise control has improved.
    This is one thing that I do not like about Toyota products. While I owned it, I did find it interesting that my Lexus didn't do this...
  17. Jan 2, 2014 at 1:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Rented a PT Cruiser in '05, it was worse. That thing was hyperactive.
    '07 Ford Explorer did it.
    '95 5.7 Suburban did it.
    '93 4.3 S-10 Blazer did it.
  18. Jan 2, 2014 at 4:17 PM
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    guess i never really noticed it in my parents automatic cars cause i didnt drive them enough or it didnt happen. just thought it was excessive in this situation. oh well, not a big deal
    i've pretty much already come to terms with it, just wanted to make sure it wasnt defective
  19. Jan 3, 2014 at 8:34 PM
    2ndchancetoyotas
    2ndchancetoyotas Well-Known Member
    Greg
    AZ
    Rebuilt
    I've got a V6 prerunner auto and yeah, the CC is fine on flat land, though the handoff from pedal to CC is slow. But going up a hill....I can hold the gear with manual pedal, but in CC, it will drop down a gear. Really weird.
  20. Jul 28, 2014 at 11:09 AM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Just found this thread searching for a similar issue. 2x4 2.4 Access Cab automatic.
    The problem is my truck never did this until recently. It would maybe go 1 or 2 over after downshifting to catch my set speed, but now it's going 5-7 mph past, before settling back down to my set speed.
    Noticed it on a recent trip through some steep hills, figured it was just more noticeable and more prolific with the 4cyl and the hills. But when I got home I realized it was doing it in daily traffic as well. Mostly after hitting the resume switch after breaking and passing traffic.
    Disappointed to hear this is expected behavior.
