Cruise control over-reving - 2006 6 cyl, Auto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SirGeoff, Mar 30, 2013.
  1. Mar 30, 2013 at 10:57 AM
    SirGeoff
    SirGeoff [OP] Well-Known Member
    Geoff
    West Coast - Vancouver Island, Canada
    2006 SR5
    Does anyone else have the problem, in cruise control, where, on climbing a hill the speed drops about 4 km, before the crusie control kicks in at warp speed (almost pinning me to the seat) until the vehicle is about 4 km above the set speed, and then levelling off.
    Controls in other vehicles I've driven are much smoother.
    Is there a factory adjustment? My Tacoma is a 2006, 6 cyl. auto, extended cab.
  2. Mar 30, 2013 at 12:15 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    My truck does the same thing. Very annoying...
  3. Mar 30, 2013 at 12:19 PM
    SirGeoff
    Geoff
    2006 SR5
    And especially when I set the cruise at a comfortable 10 km over the posted speed limit. Will be just my luck to find a cop at the top of the hill when I show 14 km over the posted limit - can I blame Toyota! lol
  4. Mar 30, 2013 at 12:21 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I think they all do it. I think they used a cruise control system from the 80's.
  5. Mar 30, 2013 at 12:21 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    ^^^ That
  6. Mar 30, 2013 at 12:28 PM
    TAKoma907
    TAKoma907 Well-Known Member
    Charles
    Alaska
    06 Tacoma
    2.5" Lift, Bilstein shocks, 10" Sub, CCFL Halo Headlights, K and N Air Intake, MagnaFlow Exhaust
    Sadly mine does this too...
  7. Mar 30, 2013 at 12:28 PM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    Yeah, I haven't used my cruise much because of the same issue. Annoying when going up a hill and it thinks it needs to be at 4k rpms...
  8. Mar 30, 2013 at 12:30 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Same here.
    Totally hyperactive.
    It's like the ECU CC circuit doesn't know the trans kicked down. Back and forth all the way up the hill.
    First time it downshifts (before it goes WOT) I plant my foot on the gas and kill the cruise until I crest the hill.
  9. Mar 30, 2013 at 6:22 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Must be an automatic thing mine works fine with the 6 SPD. It only shifts when I want it to.
  10. Mar 30, 2013 at 7:48 PM
    moondeath
    Pa, Gardners
    Mines a 6 spd also. My problem is with the uphill and the speed decreasesing, cruise control overreacts pushing my speed way over what is alright with the power hungry cop sitting on the other side of the hill.
  11. Mar 30, 2013 at 11:00 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I had a 2wd 4 banger 2006. I hated the cruise on it. Going up a hill it would slow down 5-10 below set then blast down a gear rev to over 5k and zoom to 5 MPH over set and let up and repeat. Drove me crazy. I just ended up driving in 3rd gear sometimes.
    My 2012 has a much better cruse.
  12. Mar 30, 2013 at 11:10 PM
    Waikoloa Tacoma
    Waikoloa Tacoma Well-Known Member
    At the beach, Hawaii
    2007 PreRunner DC TRD OR
    Mine does this as well. There is a fix. Look ahead for the hill and down shift to 4th gear. The transmission does not try to overcompensate and only increases the RPM by only 500 to 700 RPM. Then shift back to Drive once over the hill. I do this all the time.
  13. Mar 31, 2013 at 12:46 AM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    normal. i just dont use cruise on hilly areas, i like controlling the smiles with my foot, not the cruise, lol, always nice to make it hold 3-3500 going up hills, sounds so nice.... makes me want a trd cat back system!!!
  14. Mar 31, 2013 at 8:20 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I just don't use cruise control. There aren't many flat roads in Pa. that warrant it.
