Cruise Control Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Apr 3, 2012.
  1. Apr 3, 2012 at 9:28 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    1998 Ext Cab 5MT, TRD , SR5, 148,000 miles
    I use cruise control a lot to help with the mpgs.
    Within the last couple of months I would notice that the cruise control wouldn't set. Seemingly randomly. For most of the time, 90% approx, it works fine. But there are days where it won't set.
    During the malfunction, I can turn it on (eg push the button in on the side and have the "cruise" light up on the dash), but when I go to set it, nothing happens. I can turn the cruise off and try again and same thing. I can turn the truck off, and again same thing.
    But the next day, it'll work fine.
    So it's randomly intermittent.
    Any ideas?
    GQ7227 likes this.
  2. Apr 3, 2012 at 10:21 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    Hmmm. Interested in outcome.
    When mine went out it was my spiral cable. Yours sounds like a different problem.
    Good luck.
  3. Apr 3, 2012 at 11:24 AM
    classic42
    classic42 Well-Known Member
    18 SR5 AC
    Must be the weather. Mine just quit working too, but when I try to set the cruise light starts blinking like it has a code or something.
  4. Apr 3, 2012 at 3:09 PM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Just a thought, but have you checked the cruise cutout switch? Maybe backed off or not making contact/sticking?
  5. Apr 3, 2012 at 4:33 PM
    Madjik_Man
    That sounds like a very legit question and/or suggestion.
    Mind telling me where to even begin diagnosing that? :eek:
    GQ7227 likes this.
  6. Apr 4, 2012 at 6:46 AM
    Hillingdoner
    Rio Rancho, NM
    Clutch pedal has two switches on it. The one furthest from the firewall on the front of the pedal is the cruise switch. The switch is a simple two prong contact switch. The button on the front of the switch is depressed when the clutch is released. When the cruise is in operation and you press the clutch the cruise will disengage (sp?).
    The switch adjusts using a lock nut and threads through the bracket for the clutch pedal.
    Just was thinking that perhaps the clutch pedal is not returning all the way sometimes and as such the switch button is not being pushed or pushed enough to allow cruise operation. Either that or the switch might be loose and not adjusted out enough now to contact all the way OR perhaps the switch is going bad/dirty/sticking or has a loose plug connection.
    Simple enough to check it. First thing is look up and see the switch on the front of the pedal. Operate the clutch pedal by hand and see if it sometimes sticks and does not come up all the way to contact the switch as it should.
    If all fine and the switch is not loose and not backed off so it is not contacting then I'd take the switch out and test it with a vohm and see if it operates as it should. Looks to be a simple open/closed switch so hook up to test continuity and operate the button on it.
    Not looked at a wiring diagram to see what direction you should have continuity, but basically you should have it with the button in one position and then not have it with the button in the other position.
    Anyway just a thought on a possible cure. Hope it helps. As I said, not looked at a wiring diagram or system diagnostic, but first thought was might be the switch.
    Cheers
    Comtnyota89 and tacopashka like this.
  7. Apr 4, 2012 at 7:04 AM
    Madjik_Man
    Thank you kind sir. Will definitely check this out today.
    Cheers
    GQ7227 likes this.
  8. Apr 4, 2012 at 7:06 AM
    while
    while Member
    good luck to you .[​IMG]
  9. Apr 4, 2012 at 9:32 AM
    Rozz
    Rozz Well-Known Member
    Sturgis, SD
    '15 TRD Sport
    Stuff
    The clutch is my problem, also. I just pull up the pedal with my foot, and it sets the cruise like normal. I should quit being so lazy and fix it.
    wilcam47 likes this.
  10. Apr 4, 2012 at 9:35 AM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    As others have said it is likely a clutch switch issue. Another easy thing to check would be your brake light fuse. My brake light fuse went out on my second gen and the cruise control acted up as you describe.
  11. Apr 4, 2012 at 9:35 AM
    Asta
    Asta Hold My Beer and Watch This
    Daniel
    Kings Bay, Ga
    2014 DCSB Tacoma TRD OFF-ROAD
    Thats what mine was doing i replaced it and it works like a charm!
  12. Apr 4, 2012 at 10:22 AM
    Madjik_Man
    You just replaced the switch?
    Do you have a part number?
    Thanks
    GQ7227 likes this.
  13. Apr 4, 2012 at 10:32 AM
    Hillingdoner
    Rio Rancho, NM
    Looked at ToyotaPartszone to get the number quickly for you.
    Looks like clutch switch assembly is 88280-14030 looking under the cruise heading.
    Only takes a few minutes to check out the old one though so hate to have you buy a part you maybe don't need. If your clutch pedal is not coming all the way up then that is a different issue that needs to be fixed. If it does not come all the way up then it will not push the plunger in enough perhaps to allow clutch operation. Worth taking a look before buying the parts. Toyota parts zone wants $15.xx for it plus ship.
  14. Apr 4, 2012 at 11:04 AM
    Madjik_Man
    Totally would diagnose it before buying parts.
    Thanks so much for your help. I love TW
    Cheers
    GQ7227 likes this.
  15. Apr 4, 2012 at 11:36 AM
    Madjik_Man
    So I just went out and here's what I found:
    The connection to the switch is solid.
    If I depress the clutch pedal and push on the switch with my finger, it's flawless.
    When I release the clutch and it returns to the up-most position it appears as though it might be right at a position that would sometime depress the switch a little or sometimes not. I believe I need to adjust the switch so it extends towards the firewall a tad more. But when I tried, I couldn't adjust the threads whatsoever. There's a nut on the "dash" side of the bracket and something else (a larger nut?) on the "firewall" side of the bracket. Wtfuxxor do I need to do?
    Unless the switch is just on the fritz, I foresee the above as my problem. I guess I can always put my foot behind the clutch pedal and push it up a little more to see if that'll engage the cruise control
    GQ7227 likes this.
  16. Apr 5, 2012 at 6:40 AM
    Hillingdoner
    Rio Rancho, NM
    The firewall side nut should be made onto your bracket. The nut that is on the dash side towards the switch side is the lock nut side. Loosen this nut and you can screw the switch body to adjust as needed. Then hold in place and tighten the lock nut.
    Hope that cures it!
    Cheers
  17. Apr 5, 2012 at 8:45 AM
    Madjik_Man
    Man almighty.... the little bastid doesn't want to move.
    wilcam47 and GQ7227 like this.
  18. Apr 5, 2012 at 8:59 AM
    Asta
    Daniel
    Kings Bay, Ga
    I replaced the spring
  19. Apr 5, 2012 at 11:31 AM
    Hillingdoner
    Rio Rancho, NM
    Locknut loose? Once it is loose the switch should screw in through the bracket to adjust. Just grab the body of the switch where the plug goes in the back and turn to tighten it in. The wiring harness will twist around, but if you are not, but a turn or so off, should not be a problem to leave it plugged in. Then hold the switch in place and tighten the lock nut.
    The nut closest to the dash that is on the dash side of the bracket (towards the driver in other words) is the lock nut on my 95. Yours being the year it is should be the same from what I can see.
  20. Apr 5, 2012 at 12:22 PM
    Yota954x4
    Yota954x4 Member
    Edmond ok
    95 Tacoma 3 inch lift 33/1250/15
    3 inch lift,33/1250/15 tires, debadged ( besides yota on tailgate), aftermarket stereo
    The cluth peddle does have a lot to do with it but check out your clock spring my Toyota was Doig the same thing I jumped from the cruise control module on the lower a pillar on pass side to the switch and got the light to come on
