Cruise Control Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Argo98, Jul 14, 2017.
  1. Jul 14, 2017 at 12:07 PM
    Argo98
    Argo98 [OP] Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    Anyone else here have an issue with their CC being activated but wont "Set". My "Maintenance Required" light is on because I have to take my truck in for its 5k service... Does anyone know if that might be a safety feature built in to prevent you from setting CC?
  2. Jul 14, 2017 at 12:08 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Go through the procedure you are using to set your cc
  3. Jul 14, 2017 at 12:15 PM
    Argo98
    Argo
    Press the in on the side button of the knob (On/Off)
    Push knob down to set desired speed (I think its gotta be above 25 MPH tho)
    I've done it a bunch of times before, its worked like a charm each time... Now the icon pops up on my center console showing that its "On" but wont show that it's "Set" because it won't "Set".
    ORtoCOTaco likes this.
  4. Jul 14, 2017 at 2:37 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I know from experience that if you don't fully tighten your gas cap, then CC will not operate. Perhaps that's the cause of your issues.
    Argo98[OP] likes this.
  5. Jul 14, 2017 at 2:43 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Are you running in "S" mode?
  6. Jul 14, 2017 at 2:43 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    o_O
    OP you can turn off the maintenance warning in the settings on the head unit. It's worth a try I guess but I doubt that's it.
  7. Jul 14, 2017 at 2:50 PM
    Argo98
    Argo
    No sir
  8. Jul 14, 2017 at 2:54 PM
    Argo98
    Argo
    I can dismiss it, but it comes back every time I start the car. So no use there
  9. Jul 14, 2017 at 2:56 PM
    TejasTaco
    TejasTaco Grab a taco
    Cruise works in S mode doesn't it?
  10. Jul 14, 2017 at 2:56 PM
    Argo98
    Argo
    Gotta check... But I highly doubt it, I'm kinda OCD with that stuff, I'll tighten it twice to hear the click twice
    vuTron[QUOTED] likes this.
  11. Jul 14, 2017 at 2:57 PM
    Doggman
    Alabama
    2017 TRD OR MT
    No I mean you can reset it so that it doesn't come back when you restart. I think it's in the settings app towards the bottom. You click it to reset the maintenance warning and it'll go away completely until it's time for maintenance again. I just did it a few weeks ago.
  12. Jul 14, 2017 at 2:57 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    4th gear or higher only. It was a long shot.
  13. Jul 14, 2017 at 2:58 PM
    Argo98
    Argo
    Most cars don't, however I don't remember specifically if our trucks allow for it or not
  14. Jul 14, 2017 at 3:00 PM
    Argo98
    Argo
    10-4.... I'm scheduled to go in tomorrow at 12:45 to service anyways:notsure:
  15. Jul 14, 2017 at 3:00 PM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    I ran across this in the OM: "If the cruise control speed cannot be set or if the cruise control cancels immediately after being activated, there may be a malfunction in the cruise control system. Have the vehicle inspected by your Toyota dealer."
    Could try disconnecting the battery for a few minutes and see if it resets.
  16. Jul 14, 2017 at 3:01 PM
    Doggman
    Alabama
    2017 TRD OR MT
    Yeah they'll reset it for you or at least they should.
    Argo98[QUOTED][OP] likes this.
  17. Jul 14, 2017 at 3:04 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Only time I've noticed cruise control not working is if you turn of traction control. It works in S mode or with a gear selected.
  18. Jul 14, 2017 at 3:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    The maintenance light is nothing but a mileage ticker. Those of use who do 10k OCIs just reset it at 5k and let it roll again.
    Has it worked previously for you and now has stopped?
    Highly unlikely a battery disconnect/ECU reset will accomplish anything. But just in case it might, I wouldn't do it. Because if it affects the CC, that means there is a pending code hanging out that the tech needs to be able to read.
    Either way, since you're going to the dealer anyway, warranty work is in order.
    Garyji and Argo98[OP] like this.
  19. Jul 14, 2017 at 3:07 PM
    Argo98
    Argo
    This is true... However it is worth to mention that my traction is ON and I am in regular Drive, not ETC (or ECT... Kinda forgot which it was) and not in "Sequential" mode either.
  20. Jul 14, 2017 at 3:07 PM
    Argo98
    Argo
    It used to work fine before... Just recently started
