Cruise Control Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pilvr83, Sep 13, 2018.
  1. Sep 13, 2018 at 4:52 PM
    Pilvr83
    Pilvr83 [OP] Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    Once I set my cruise on my 2018 to any speed allowed I cannot use the speed up function and reset a new speed.
    What i mean: once i set to say 55mpg and then decide i want to speed up to 60 via the cruise control up arrow. I want to set it now at 60 but the cruise control does not allow.
    I turn on the cruise to a speed, turn off the cruise, get to my new speed and reset the cruise.
    Normal for the Tacoma?
  2. Sep 13, 2018 at 5:06 PM
    bah327
    bah327 Member
    Brett
    2018 Bright White DCLB OFF ROAD
    Nope. The only thing that could be happening is you are trying to speed up when too close to another vehicle. The safety sensor will keep you at a set distance from them even if your cruise is set to 160mph.
    If there is no traffic ahead of you then I am thinking you need to discuss with the dealer.
    oconnor and mtip like this.
  3. Sep 13, 2018 at 5:21 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Could be the safety sense if you're following somebody. You should be able to hold the stalk up though and the C.C. speed (above the actual speed) should go up. I just hold mine up or down until it hits the desired speed, the truck then accel/decels accordingly.
    NoOne likes this.
  4. Sep 13, 2018 at 5:37 PM
    scottosaurus
    scottosaurus New Member
    2018 Blue Tacoma TRD Sport 4x4
    On mine when I set the cruise it shows the speed it is set at, when I click the lever up or down it moves my set top speed up or down accordingly. It will update that number even if the vehicle won't speed up due to being too close to the car in front of you. If that number isn't updating, then take it to the dealer cuz something's up.
    Boyitz and NoOne like this.
  5. Sep 13, 2018 at 5:54 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    1 click of the stock up or down, equals 1 mph +/- of CC speed. Or hold till desired speed is reached.
  6. Sep 13, 2018 at 5:54 PM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    Thank you. I had not thought about the safety portion. I will try tomorrow morning on my commute without following others.
  7. Sep 13, 2018 at 5:58 PM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    OH, I see I might have a problem as I know mine does not increase on the display.
  8. Sep 13, 2018 at 6:03 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    There's two spots. One that displays your current speed. The cruise speed will display in smaller font just above and to the right of the regular speed readout. If you're not looking for it, it could be easily missed.
  9. Sep 13, 2018 at 6:22 PM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    Ah, okay. Now I really have to investigate tomorrow. Wish the truck would drive itself like the Honda CRV while doing these checks! I see an accident in my future!
  10. Sep 13, 2018 at 6:29 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Are you increasing to 60 then trying to reset your cruise?
  11. Sep 13, 2018 at 6:38 PM
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    You're kidding me??? I will shit my pants if my truck displays my cruise set speed anywhere. I have never seen it
  12. Sep 13, 2018 at 6:38 PM
    toyotatacomaTRD
    You've got a 17. It's part of TSS in the 18s. I'm sure that's why you haven't seen it.
  13. Sep 13, 2018 at 6:39 PM
    Maniac64
    Maniac64 Active Member
    2018 Sport 4x4
    I used cc on 18 hours of freeway driving recently, loved the adaptive cruise control, was able to adjust speed with controller.
  14. Sep 13, 2018 at 6:39 PM
    Loaded NightraiN
    17 TRD Off Road
    Ok, thanks for the clarification
  15. Sep 14, 2018 at 9:50 AM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    Well, I did my morning commute test...Yes, I can increase/decrease with the up/down arrow on the control itself. I cannot set the cruise control at say 55 then speed up via the gas pedal and set a new speed at say 65. It goes back to the original speed of 55 no matter if anyone is in front of me or not.
    I still have to turn off the cruise then reset at the new speed.
    With this issue, is this something I need to bring the truck in to the dealership to check?
    Thank you again.
    Greg
  16. Sep 14, 2018 at 9:52 AM
    toyotatacomaTRD
    It's working as it should. If you want to speed up with the pedal, turn off cruise, then reset once you're at the desired speed. I actually prefer adjusting with the switch myself.
    bv8ma, tacoguy88 and ST77 like this.
  17. Sep 14, 2018 at 9:55 AM
    kbUSMC2012
    kbUSMC2012 Well-Known Member
    Kevin
    2019 TRD Off Road 4x4
    If you hold down the cruise control button for like 3 seconds it will convert to normal cruise control and you’ll see the display change from “radar ready” to “cruise control” and that should allow you to speed up and down with the cruise control lever. I have to do that on my wife’s car because she has the TSS and I can’t stand it lol
  18. Sep 14, 2018 at 2:51 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Sounds like the adaptive CC is working the way it should. Takes a little getting used to. I only use it on longer trips with light to moderate traffic. One tap turns on adaptive radar CC or press & hold for regular CC. From there you can also set the sensitivity to how close you follow behind the vehicle in front of you. Kinda nice that it displays your CC speed in the top right corner. Didn't even notice the first couple times!
  19. Sep 14, 2018 at 7:04 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Can't you just press 'set' at your new speed? Otherwise yeah it's going to revert back to your set speed of 55.
    shakerhood likes this.
  20. Sep 14, 2018 at 7:27 PM
    Loaded NightraiN
    17 TRD Off Road
    I'm able to do this with my 17 just fine. Maybe just a side affect of the TSS?
