Cruise control quit working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saltybum, Dec 21, 2021.
  1. Dec 21, 2021 at 10:22 AM
    saltybum
    saltybum [OP] Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    About a month ago coming home from a hunting trip my cruise wouldn't engage. Light comes on in dash but cruise doesn't work. Research shows that since the light is on it's likely not a fuse but actually the mechanism in the wheel. Also read where "be very careful around airbag" when replacing it. Hmmm. I'll be selling it very soon and really don't want to fix anything else I already have before letting it go and especially at the risk of creating another issue.
    Thoughts? Is it hard to fix etc.?
    Thanks
  2. Dec 21, 2021 at 10:24 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I got nothing unless it’s the clock spring.
    It’s very easy to replace. If it is the problem make sure you order the correct one, different for radio controls or not on the steering wheel. Goood luck
  3. Dec 21, 2021 at 10:25 AM
    Mudtime4me
    Mudtime4me Well-Known Member
    Richard
    Lexington North Carolina
    2012 Silver Double Cab Tacoma TRD
    Third brake light bulb?
  4. Dec 21, 2021 at 10:44 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you can turn the light on and off with the switch that tells me the clockspring is good because all functions on the cruise are on a single wire.
    I would make sure the brake and clutch (if equipped) cancel switches are working properly.
    What year and engine do you have? I can post a wiring diagram.
  5. Dec 21, 2021 at 11:02 AM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    2005 4 banger standard trans. Clutch cancel switch works fine. I will check the third brake light as soon as rain quits. 5" in 24 hours so far.
    Thanks everyone.
  6. Dec 21, 2021 at 11:24 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Here you go.
    There's 2 switches on the clutch pedal, one is for the cruise the other is for the starter.
  7. Dec 21, 2021 at 12:04 PM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    Well I got under there and I can tell which one is the clutch cancel starter switch but nothing else that looks like a switch to me.
  8. Dec 21, 2021 at 12:36 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The one for the cruise is at the top of the pedal assembly near where it pivots and is depressed when the pedal is released, the one for the starter is closer to the firewall and is depressed when the pedal is released.
    TnShooter likes this.
  9. Dec 21, 2021 at 12:54 PM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    Thanks Dm93. If you have that wiring diagram it might me help figure this thing out. Otherwise it'll be the new owners challenge.
  10. Dec 21, 2021 at 12:59 PM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    For got to mention I just got a new 2022 last week and 2005 is going to be sold as soon as I detail and clean it up.
  11. Dec 21, 2021 at 2:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I posted it above.
  12. Dec 21, 2021 at 2:55 PM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    Got it. Thanks
