Cruise control stick often stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TigerShark, Jun 20, 2016.
  1. Jun 20, 2016 at 4:49 PM
    TigerShark
    TigerShark [OP] Member
    2009 Tacoma TRD Off-Road
    Just got an '09 and will likely be posting more questions here about various aspects of it (especially off-roading, as I'm totally new to it), so hopefully I'm posting in the right place for this.
    The cruise control stick is often stuck. The button on the end to turn the cruise on works, but the lever can't be moved up or down to engage the CC to set the speed. I've tried to force it, but that doesn't seem to help. Usually after I wait a few minutes and try again, it works as if it was never stuck.
    I searched the forums and Google but couldn't find an answer to my solution.
  2. Jun 20, 2016 at 4:53 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Maybe theres something inside that obstructs the lever but then moves when the steering wheel gets turned. Cant say for sure but that'd be my first guess.
    TigerShark[OP] likes this.
  3. Jun 20, 2016 at 7:25 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    My first thought is simply replace the complete switch. Not that hard a job and the part is not ridiculously expensive either.
    JeffreyB and DustStorm4x4 like this.
