Cruise control stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by db4boat, Aug 20, 2020.
  1. Aug 20, 2020 at 9:15 AM
    db4boat
    db4boat [OP] New Member
    2008 Tacoma 6 cyl auto TRD SPORT
    None
    Hi looking for some input cc stopped working will not turn on. However does turn on and off with steering wheel turned all the way to the left. I suspect the spiral cable wondering if anyone has had similar symptoms and what was fix. No error codes.
  2. Aug 20, 2020 at 9:24 AM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Horn working? I suspect the clock spring may need replacing. Not a difficult job or an expensive one.
    VanDoom and whatstcp like this.
  3. Aug 20, 2020 at 9:26 AM
    db4boat
    None
    Yes horn and all other steering controls for stereo work
  4. Aug 20, 2020 at 9:59 AM
    db4boat
    None
    Now after jerking the wheel all the way to the left repeatedly it is now working wonder for how long? Can get it to turn on and sometimes set a speed.
  5. Aug 20, 2020 at 4:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Definitely the spiral cable.
  6. Aug 20, 2020 at 4:51 PM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I second his definitely,
    Just had this happen on mine. Everything BUT the cruise worked. Spiral cable replacement was the ticket.
    its 100% possible for just one wire to get broken. Search for spiral cable threads, they have pics where its only one or two wires.
    now on to the bigger question.... OEM or cheap Amazon.. :devil:
  7. Aug 20, 2020 at 6:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  8. Aug 20, 2020 at 6:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Most likely is the clock spring assembly.
    Make sure you do not have an intermittent voltage regulator in the alternator. Low output voltage will prevent the cruise from working proper.
    po35042 likes this.
  9. Aug 21, 2020 at 11:49 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    My clockspring was replaced under warranty after the ABS light came on. It's a few years later, now, and the cruise quits the same way... can get it to work during a turn... clockspring.
    Be sure to order the proper one. There are a few options which have to do with having stereo controls, cruise, or not.
  10. Aug 22, 2020 at 2:46 AM
    Bagman
    Area 51
    Here's the one I used off ebay
    OEM 84306-48030 84306-0E010 Air Bag Spiral Cabl Clockspring for TOYOTA & LEXUS.
    ( 143289523954 )
  11. Aug 22, 2020 at 3:54 AM
    db4boat
    None
    Thanks all! The cruise started working, at least for now, after repeated working of steering wheel all the way to right and left multiple times. It’s Been stable for two days (agree it’s that cable) will await symptoms to come back and update.
  12. Aug 22, 2020 at 5:11 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    spiral cable is ridiculously expensive from dealer over $500! installed
