Cruise control suddenly stopped working
Discussion in 'Technical Chat' started by s2kvtak, Jan 4, 2010.
  1. May 26, 2017 at 4:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yes its under the dash, if you look where the clutch travels you'll see a switch that engages when the clutch touches it. if your clutch pedal sags thats most likely why its not engaging CC. You can adjust the switch a little to get it to work right.
  2. Jun 4, 2017 at 9:46 PM
    Nbrannon92
    Nbrannon92 Well-Known Member
    Nick
    Houston, TX
    97 Tacoma 4x4
    I adjusted my switch and I'm all good now. Thanks!
    wilcam47[QUOTED] likes this.
  3. Jun 5, 2017 at 7:56 AM
    wilcam47
    Will
    Bourbon state
    I like cruise control to work if its equipped....
  4. Jun 10, 2017 at 9:09 AM
    Nbrannon92
    Nick
    Houston, TX
    97 Tacoma 4x4
    So I adjusted the switch on my clutch and the cruise control started working again. Then three days ago it went back to not working. Just looked at the brake and clutch switches and both are positioned correctly. I don't know what to look at next. The cable is still tightly attached to the bracket as it should be. Light still comes on btw. Do I need to start checking wires?
  5. Oct 11, 2017 at 10:32 PM
    4pntlifted"
    4pntlifted" Active Member
    Zach
    2008 White Tacoma TRD 4x4
    08 auto 4x4 v6 sr5. no light nothing the CC switch is complete dead. nothing no light or anything. any clue what to check first?
  6. Oct 14, 2017 at 7:11 PM
    wilcam47
    Will
    Bourbon state
    Fuse? or some cases clock spring but Im not experienced in that
  7. Nov 27, 2017 at 2:10 AM
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
    IM having the same issue. At first the cruise control turned on whenever it wanted to, now it doesnt turn on at all. 06 Auto 4x4 TRD Sport 4.0
  8. Nov 28, 2017 at 8:25 PM
    Taco'09
    Taco'09 Well-Known Member
    Has your clock spring (aka spiral cable) been replaced? Also, check the level of your brake fluid as that is a known cause albeit rarely.
  9. Apr 13, 2018 at 7:38 PM
    beenexposed
    beenexposed Member
    Nomad
    02 taco trd 4x4 with dents
    Once agin TW to the rescue!!!! My clutch was not traveling to the top of the stroke.
  10. Dec 8, 2018 at 12:22 PM
    Boondox
    Boondox Member
    Louisiana
    2000 Tacoma SR5 automatic
    Step bars, textured bed, all audio changed.
    So light comes, auto, 2000, nut washer brake fix wasnt it and fuses are good. It doesn't engage at all. anything else that's easy fix?seems like something si.ple and read all post and everyone fixed theirs easily. Suggestions?
    tcjacado likes this.
  11. Dec 8, 2018 at 12:26 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
    Your cruise control isn't working?
  12. Dec 9, 2018 at 12:33 PM
    Boondox
    Boondox Member
    Louisiana
    Yeah lights on but doesn't set
    It
  13. Dec 9, 2018 at 12:37 PM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    If it is a manual, your spring on your clutch could be going..
    My 2000 Manual would not engage cruise. Just had to use my toe and lift the clutch pedal the last 1/4”-1/8”..would work just fine..
  14. Dec 13, 2018 at 5:27 AM
    Boondox
    Boondox Member
    Louisiana
    No its v6 4 speed
  15. Dec 13, 2018 at 5:29 AM
    #35
    Boondox
    Boondox Member
    Louisiana
    If the light is still coming on, on the cruise switch could the fuse be blown still?
  16. Dec 13, 2018 at 4:55 PM
    #36
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    Most things that will cause this is a faulty brake switch or loose emergency brake cable, Make sure your pull brake is not loose so just tugging it lightly and seeing if your brake light comes on. If that is good, do a resistance test on the brake switch. There are 4 pins on it, 2 and 2. depress the plunger and make sure that 2 or the pins have go resistance as well as the other 2.
  17. Dec 17, 2018 at 6:23 AM
    #37
    Boondox
    Boondox Member
    Louisiana
    I'm having problems with the e brake not showing the light when it's on. I've been driving and let off gas and speed drops quickly but not as if a brake was on and no light, but I pulled over and pulled it and pushed it in again and it was back to normal. Android audio wont work with USB on head due to saying I'm not stopped And if I am stop to engage the emergency brake and when I do it it's still does not let me accept the terms and conditions so it'll run the same screen on my head unit. It has to be a problem with the emergency brake but I don't know what you mean when you say pull the plunger and 2 pins. Can you send a picture of what pains are talking about or send me a link to how to fix it?
  18. Dec 18, 2018 at 2:18 AM
    #38
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Are you having trouble with your radio, or your cruise control?
  19. Feb 14, 2019 at 11:48 PM
    #39
    Coastalkid79
    Coastalkid79 New Member
    '03 Tacoma Ext Cab 4x4 SR5 V6 5spd
    2.5" N2.0 Rough Country extended strut lift, (front) & 1.5" blocks with Bilstein 5100 series Shocks (rear).
    Man this site is awesome. With everyone's knowledge I would think that any Yota owner can figure out a problem and fix it themselves. Two thumbs up!
  20. Feb 21, 2019 at 2:21 PM
    #40
    Burgy98
    Burgy98 Member
    Found out what my issue was. The plug and play trailer pigtail has a short in it. Noticed that the marker lights and dash panel were coming on when I pushed on the brakes. So the short in the pigtail was back feeding making the truck think I was pushing on the brake when turned the lights on. Now to buy a new trailer pigtail.
    mtnkid85 likes this.
