Cruise Control Usability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roth_nj, Sep 29, 2015.
  1. Sep 29, 2015 at 8:56 AM
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    I wanted to ask the question after having to take a trip up to Maine this past weekend. no issues with traffic or anything. Just cruising at 75.
  2. Sep 29, 2015 at 9:25 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    +1, its all about power. My car doesn't drop more than 1mph even in mountains. Doesn't down shift out of 6th.
  3. Sep 29, 2015 at 9:56 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Only partially true, as the gear ratios come into play. Chest thump all you want, but the 'Yota CC problem, at least in the '05~'15 4.0, is real. It waits far too long to ramp up and is equally slow on the ramp down. If you re-gear higher the problem is less, but still there, as the ECU is slow to respond.
    Wow, worse case of apples and oranges in a while. Comparing a F/I to a N/A. At least use the S/C numbers if you want to be close. BTW what rpms does that roll at 65?
  4. Sep 29, 2015 at 10:05 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    All about timing..............
    Radelix[QUOTED] likes this.
  5. Sep 29, 2015 at 10:05 AM
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    I live in L.A. and CC does not work under 30 MPH :(
    2016_dbag likes this.
  6. Sep 29, 2015 at 10:06 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Use Crawl Control instead?
  7. Sep 29, 2015 at 10:07 AM
    Radelix
    Los Angeles
    17 trdor dcsb 6mt
    I drive a manual cause I'm better than you
    2016_dbag[QUOTED] likes this.
  8. Sep 29, 2015 at 10:40 AM
    roth_nj
    exactly... my curiosity for asking and hope is that with the new engine, extra tranny gear, and hopefully smarter computer, it would be better on the 16's
  9. Sep 29, 2015 at 10:46 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    yep, whole different issue that highway with hills. I am OK with the converter lock up but when it starts dropping to 4th I will kick cruise off. I use it for short periods on long drives to avoid cramps in my right leg.
  10. Sep 29, 2015 at 10:53 AM
    Michael252
    Michael252 Well-Known Member
    Near Dallas
    I didn't use the cruise on my '14 more than a couple of times in 30k miles (haven't used it on the '16 yet). But what I didn't like about it was that when I came to a hill or rise, the truck would slow down, then drop a couple of gears in a late shift then try to make up for it by really getting into the throttle.
    Stig likes this.
  11. Sep 29, 2015 at 12:34 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Anyone use adaptive cruise control in a vehicle that has it?
    Wish Ford had it as an option on their lower end models and Toyota offered it.
    I love it. Only real new technology in vehicles that I really like. That and the tailgate step.
  12. Sep 29, 2015 at 12:36 PM
    Radelix
    Los Angeles
    17 trdor dcsb 6mt
    I see the appeal of it but its not something that I specifically want.
  13. Sep 29, 2015 at 1:00 PM
    taco206
    taco206 Well-Known Member
    Toyota cruise control sucks. My 05 Tundra DC 4x4 V8 down shifted all the time from 5th to 4th and even 3rd! Such BS, I just never used it unless it was 100% flat, it was that annoying. Same with other Toyotas in the family. Very annoying.
    Most likely the 2016 will behave the same way because its cruising at such a low rpm for mpgs sake. No way it'll stay in 6th when Toyota V8s with gobs more torque cant even hang in 5th.
    Actually my 2004 Accord 2.4L auto usually stays in 5th in CC on the hills where the Tundra was downshifting.......Something wrong there.
    TheTacoHunter likes this.
  14. Sep 29, 2015 at 7:27 PM
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Fifth gear in gen3 (V6 AT) is almost exactly the same as 5th in gen2; so, if gen2 is downshifting to 4th, gen3 would almost certainly do the same--but that will be two gears. Wonder if it would go from 6 to 4 directly?
    My gen1 will go through an endless cycle of 4(locked), 4(unlocked), 3, 2, 3, 4(unlocked), 4(locked), 3, 2, ... up a steep interstate until I intervene. Pretty close to +/- 10 mph. It downshifts/unlocks much sooner with cruise on than off.
  15. Sep 29, 2015 at 8:24 PM
    #35
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Get an OR with crawl control!
  16. Sep 29, 2015 at 8:39 PM
    #36
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I like/use my cc all the time. It's mostly very flat down here, but still run into a few hills. During the first 500 miles or so I did notice the transmission downshifting late and upshifting late, with higher revs and mph than cc was set at. After the first 500 miles it seemed to loosen up or something. I'm driving the same roads also. Maybe I just got used to it. I'll have to keep that watched. I think I would have noticed that though, if it had continued. Might just be a break in issue that solves itself.
  17. Sep 29, 2015 at 8:51 PM
    #37
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I doubt it will be much different.. Especially since it sounds like the torque curve is worse down low on the new engine.
    Speaking of which a dyno would be nice for this engine.. feel like manufacturers should supply these for consumers to view.. it's not like they don't have them.
    It is about power though.. my car holds 92 (CC max) within 1mph no problem up even the biggest hills on I65 in North Alabama. It does have a manual box so downshifting is not an option for the computer.
  18. Sep 29, 2015 at 8:58 PM
    #38
    addicus24
    It's gonna get it from torque or horsepower. You want it to use torque as much as possible. Watch the YouTube video where they tow the trailer up the Ike Gauntlet using a 2015 Tacoma. Have they done that tow with the 2016 yet?
  19. Sep 30, 2015 at 8:43 AM
    #39
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I live in Houston, TX but the timing part on using the cc involves driving my 30 miles to work at 4 a.m. before rush hr................L.A. rush hr = 24 hrs so I could see where that could be an issue.
  20. Sep 30, 2015 at 9:26 AM
    #40
    Radelix
    Los Angeles
    17 trdor dcsb 6mt
    I also work near the airport and live near DTLA so my traffic is a mixture is commuters, Express lane, general assholery, and airport traffic. Times also vary from 4 AM to 9 AM Its a real party sometimes. Much better than my commute to southern Orange County that I used to have to do.
