Cruise Control Usability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roth_nj, Sep 29, 2015.
  1. Sep 30, 2015 at 4:27 PM
    #41
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    No "partial" to it. My car has 2.92 gears. Here is a vid pulling a 6% grade. Cruise set at 59mph. TCC never even unlocks.
  2. Sep 30, 2015 at 7:45 PM
    #42
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I see I was correct about chest thumping. What are the specs on your G8? LS3 and 4k lbs with 26inch low profile tires? Apples and oranges.
  3. Oct 1, 2015 at 3:16 AM
    #43
    Aussiek2000
    2016 Offroad AC
    6.0l L76, makes 470 to the wheels, 550+ at the crank. 4300# with me in it. 27" street tires.
    I can make the same video with a 8000# 2500hd and a stock 6.0 with 3.73 and 33's
  4. Oct 1, 2015 at 8:38 AM
    #44
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    You should consider making a new thread, or even two, as I'm sure there are others that are interested in your vehicles that will never find your posts in a thread for cruise control.
    I hope your race that G8, as having that much horsepower and torque spend it's life on the street is really so much untapped potential that it would be a shame.
    Tacomas are all about the combination of efficiency and durability, and the 2nd gen power-train is pretty hard to beat. Most of us with backgrounds in engine and power-train building have been anticipating changes in the gear ratios and power curves to achieve higher fuel economy while maintaining the utilitarian aspects in a durable power-train.
    So to get back on topic, has anyone tried the '16 cruise control, running for 50 miles on the flat then hitting some hills to see if it loses it's mind?
    I saw the post stating that the ECT does not seem to have much effect.
    https://www.tacomaworld.com/threads/300-miles-later.393713/#post-10867961
    TheTacoHunter likes this.
  5. Oct 1, 2015 at 10:25 AM
    #45
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    if its anything like the CC of late for Toyota's, then it will bog down going up hills. once the set speed is -3 or -4 mph, it will kick out of overdrive. once it hits -5 mph or more it will kick down a gear.
    the biggest issue I have is the brains for the CC takes forever to kick up a gear or into overdrive once its past a hill, it tends to hold 4th gear way to long to the point I have to disengage CC or I help the gas pedal compensate for the hill before I get to it, or (this is what I usually do), manually kick it down to 4th (in my 2012 Tacoma and 14 4runner).
    something about backpressure keeping CC from upshifting from what I heard 3rd party.
  6. Oct 1, 2015 at 10:32 AM
    #46
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    I use CC every day to/from work and I've never had any issues with it. Then again I don't expect too much from a cheap (relatively speaking) truck.
  7. Oct 1, 2015 at 10:33 AM
    #47
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I love my cruise control in my '13. Works pissah. I'm in hilly NH too.
  8. Oct 15, 2015 at 4:53 PM
    #48
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    Bumb... Now that a lot of people seem to be getting them
  9. Oct 15, 2015 at 6:00 PM
    #49
    BillyM67
    BillyM67 Well-Known Member
    2014 Silver Avalon Limited
    Must be Tacoma thing, because the cc in my '14 Avalon works great and I use it all the time.
  10. Oct 15, 2015 at 8:37 PM
    #50
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    Back on topic here... I've been using the CC on the '16 often since I got it, I've been on a few long trips around sw colorado and utah and it works pretty good. It downshifts quickly on hills and stays within 5mph of the set speed. Sometimes it does shift one gear higher than I would like, but it's not often enough to call it annoying. The downshift for downhills or back to normal is also pretty quick unless you just finished climbing a steep hill and it doesn't go flat at the top, but instead is just a lower grade climb, the truck will stay in whatever gear it was in on the climb for a while. Either way, it stays within a few mph of set speed in any condition, and shifting is pretty quick either way.
    Tharris242 likes this.
  11. Oct 15, 2015 at 10:55 PM
    #51
    tpak
    tpak Well-Known Member
    chris
    Colorado
    '16 DCLBOR JBL 4x4 Blazing Blue FTMFW
    Also in Colorado and have been using it - seems to be fine so far. It holds within 2 MPH based on the digital readout. I have noticed that the digital readout and the analog readout of the speed seem to be off a little - the digital one is higher - I need to check it against GPS to see which is correct. One thing that it would be nice to have which seems like an oversight is a display of what it is set to .. recent '15 Camry rental I used had that - was kind of nice. Other than that it seems fine on highways. I don't use it around town and haven't had it on state highways at lower "high" speeds yet and those are usually rather hilly so I don't bother.
  12. Oct 25, 2015 at 9:22 PM
    #52
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Not sure if already mentioned but does the cruise control indicate digitally somewhere what speed you're set to?
  13. Oct 25, 2015 at 9:52 PM
    #53
    smitty99
    Scottsdale
  14. Oct 26, 2015 at 12:37 AM
    #54
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    Literally just walked in the door from a 14 hour drive in my 2016. It works fine, but like most everyone else I kicked it off when I saw a hill coming to keep the tranny from kicking down. Works better than my V8 4Runner though.
  15. Oct 26, 2015 at 1:04 AM
    #55
    Derek G
    Silverton CO
    2016 TRD OR DC
    Unfortunately no, at least I haven't seen it. There may be a way to set the display to do so. There are so many options and customizations for what info you have displayed and where.
