Cruise control useless
Discussion in '1st Gen. Tacomas (1995-2004)' started by rkd1119, Jul 22, 2010.
  1. Jul 22, 2010 at 12:01 PM
    rkd1119
    rkd1119 [OP] Well-Known Member
    Robert
    L.A. (lower Alabama)
    ‘23 Trail Edition Ice Cap
    I have an 04 DC with the 3.4 V6. It seems to have enough power, but when I use cc on anything but flat ground, it will upshift way too often.
    Seems like a lack of torque at hwy speeds 65-75 mph. Anything I can do to help it?
  2. Jul 22, 2010 at 12:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When was the last time the spark plugs were changed? A/F sensor?
  3. Jul 23, 2010 at 6:48 AM
    rkd1119
    Robert
    Never probably. I bought the truck last december with 65K miles. It has about 90K on it now.
    I thought about doing the plugs myself. I saw some Bosch platinum 4 tip plugs at O'Reilly's and thought about getting a set of them. Need to change the fuel filter, do a tranny flush, and maybe a timing belt/water pump job.
  4. Jul 23, 2010 at 6:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    Avoid the Bosch plugs and stick with the factory Denso or NGK plugs. The 3.4L is extremely finicky about plugs.
  5. Jul 23, 2010 at 7:14 AM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    My 03 did that when I used the CC I would turn on the ECT button that help holding the speed.
  6. Jul 23, 2010 at 7:09 PM
    rkd1119
    Robert
    Thanks, I'll stick with them. Did I read a how to post on swapping plugs that said they came with Denso on one bank and NGK on the other or am I dreaming that?
    Thanks also for the ECT tip, I'll give that a try too.
  7. Jul 23, 2010 at 7:17 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Nope, you're not dreaming it. This is how they come from the factory, many theories on this and no reasons why from Toyota.
    I have a theory on this but it involves BigFoot and the guy on the grassy knoll, but we'll just leave it at that.
  8. Jul 23, 2010 at 9:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Not sure about the grassy knoll thing but I had a big foot sighting.......:rolleyes:
  9. Jul 24, 2010 at 6:52 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    mine does the same i changed plugs, deck plate w/ k&n, magnaflow cat back it still does it even w/ stock tires if you figure it out let me know
