Cruise Control Went Out?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoCat37, Jan 6, 2022.
  1. Jan 11, 2022 at 4:21 PM
    Glamisman
    Glamisman Well-Known Member
    I did a little more digging... do you have a drive by wire throttle (ECTS) or a cable from the pedal. Apparently the cruise control for each is different.
  2. Mar 13, 2022 at 12:35 PM
    sputnik378
    sputnik378 Member
    Salida, CO
    1996 Matte Black Tacoma
    ARB Front, 4x4 Innovations Rear with 2" receiver hitch, 3" Pro Comp Lift, Tundra Breaks, BIG STUPID rims and tires... Not tall enough to fit them, but it seemed a good idea when I was being convinced.
    I have this issue intermittently.. It happens when I climb a hill and forget to turn off the cc. It will hold as long as it can and then you can feel a small *pop* in the gas pedal and then the cc light starts blinking. I feel like it won't work again until I restart the truck, and even then sometimes it doesn't work still.
    I have a cable driven cc btw.
  3. May 31, 2022 at 8:17 PM
    TheloniusDrunk
    TheloniusDrunk Well-Known Member
    99 3.4L M/T 4WD 220k
    I've got a '99 Manual 4x4 3.4L and the cruise control hasn't worked since I purchased it used a year go. Light doesn't come on and nothing engages. It's cable driven. Judging from a few responses here it looks like I should check fuses, any other leads to dig up?
  4. Jun 2, 2022 at 2:26 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Easy enough to unplug your trailer harness and check if it fixes the cruise issue. Just my two cents
  5. Jun 2, 2022 at 1:41 PM
    alexh
    alexh Well-Known Member
    1998 TRD
    I don't use mine much but I think it stopped working when I added the trailer wiring - why?
    The light comes on but cannot engage. Anyhow CC does not seem to work too well on a manual.
    OK just saw previous post - unplug wiring
  6. Jun 2, 2022 at 4:14 PM
    Rastopher
    Ras
    Sacramento, Ca
    I believe in cases similar to yours, the trailer harness wiring had either been set up or degraded in a way that caused the brake switch to be active all the time. So in these cases, the cruise control was automatically cancelled or never even set due to the brake being “on”. Similar to how applying brakes should turn cruise control off.
  7. Jun 3, 2022 at 7:31 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    I have a CC that works perfect most of the time for long drives then all of a sudden doesn’t, but if I tap the brake while driving (3.4 5 spd) cut it off and back on it comes back to normal…Weird but I can use it until I figure the bugs out.
  8. Jun 3, 2022 at 10:31 AM
    alexh
    1998 TRD
    It may be that these old style CC are not that reliable - I had a Mustang and I used to take long trips on less traveled roads so used CC a lot. Once was coming up on a curve fast so tapped the brake to disengage and after about 1 sec the CC re-enaged by itself. Scared the hell out me just because it was so unexpected and I dont think I ever used it again. As I recall the early Prius had some scary intermittent issue with CC also.
    https://www.cnn.com/2010/US/02/11/prius.cruise.control/index.html
    alarka[QUOTED] likes this.
  9. Jun 5, 2022 at 9:32 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Have you checked the switch on the brake peddle or clutch? Might need to be adjusted.
  10. Jun 5, 2022 at 11:15 AM
    alarka
    WNC/SE GA
    2k X cab 3.4 5spd
    Those two are the suspects and I’m leaning towards the brake as it takes multiple presses to get the cruise to come back on.
  11. Jun 5, 2022 at 5:54 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    It's an easy fix. Just back out the switch and tighten it down
